Hitachi LED tv 24" with DVD combo
  • hernan_perez_br
    • Jan 2011
    • 37
    Hi all, I am having an issue with a Hitachi LED Tv 24" with DVD Combo.
    I found the DVD on the street with looks in mint condition but obviously is not working so I decided to give it a try.
    It is a model le24ecd05au, the power rating is 12v 4A, I do not have a 12v 4A transformer but I connected a 12v 1.5A transformer and I plugged in the TV
    it shows an standby red light and when I press the power button it shows a blue light (power on light) but I cant see any picture or even the Hitachi logo.
    Initially I thought it could be because I am using a 1.5A transformer and the TV does not have the power to power on. but I tried pressing the "eject" button
    of the DVD and the TV powered on, showed the Hitachi logo and power on, I could see the menu, etc, all fully working. I inserted a dvd, etc and it was working.
    Then I power off the TV and I could not get it working again, the eject button did not work anymore, I have to dissasemble the tv to eject manually the DVD.
    Do you know what could be the issue with this TV? I think it is not the PSU because it is a 12v TV.
    Any help will be more than welcome!
    Re: Hitachi LED tv 24" with DVD combo
    There is a reason it is rated at 4 amps. You cannot be sure if a 1.5 amp supply will be able to supply all the current required, for example during eject it might draw an additional amp of current to get the eject motor turning.
    • hernan_perez_br
      • Jan 2011
      • 37
      Hi thanks for the reply, yesterday I used a power supply 12v 7.5A, and it does the same thing. I was able to start the tv 2 times and it works perfectly, the TV, HDMI, VGA, DVD, all works OK.
      but I tried many many times and only 2 times it started, all other times only the blue light is on but nothing happens on the screen.
      When the tv starts it should show the blue light and the hitachi logo on the screen, but around 95% of the cases it will just show the blue light only.
      Thanks !
      • learnmore
        Help choosing replacement transformer for Levoit 600S SMPS
        by learnmore
        Hello Community,
        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
        Peace
        LM...
        11-04-2025, 09:35 AM
        Lithonia Lighting versus Light of America Compact Fluorescent product quality
        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
        I also have back when Light of America had these light bulbs available for yard lights
        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
        While the Lithonia lighting fixture has all most certain bulb failure
        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
        I have only had this light fixture for not more than a year if it...
        07-02-2023, 03:45 PM
      • Markie76
        Hitachi DV-PF4E VCR/DVD Combo - no power
        by Markie76
        I have a Hitachi DV-PF4E VCR/DVD Combo unit which is dead - no power.
        Last used and working ok about a year ago.
        Then it has stood unused in the tv cabinet unplugged from the mains.
        I went to use it this week, plugged it in and nothing happens, no display/lights, no response when pressing standby button.
        Opened to check and fuse ok, ac supply ok, caps all look ok, other components & pcb look ok with no trauma visible.
        Any cause for it to just go 'bad' by not being used for a year?
        Thanks,...
        12-24-2022, 05:54 AM
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
