VIORE Plasma PDP42V18HA Flashing
  • madoc53ohm
    • May 2012
    • usa
    Re: VIORE Plasma PDP42V18HA Flashing
    Think i'll do the same. Boards are to expensive to do guess work! Thanks for responding.
    • STKR123
      Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
      by STKR123
      As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
      I wonder if re-flashing the BIOS might be of any use here.
      As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
      There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
      11-03-2024, 06:58 AM
    • learnmore
      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
      by learnmore
      Hello Community!
      CASE DETAILS
      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
      Tried inserting firmware on USB and left it in for a few hours, but no change
      03-03-2024, 09:49 AM
    • 7ony
      Samsung plasma - flashing standby light
      by 7ony
      The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
      Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
      Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
      No visible...
      08-31-2020, 05:18 PM
    • KYBOSH
      VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
      by KYBOSH
      Got my hands on an relatively unknown TV brand about two weeks ago.
      I certainly hadn't heard of it before.
      Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
      I put it on the back burner until I had so spare time to look it over.
      Today was that day.
      I plugged it in and was surprised to see that it started up without any issues.
      This is an older TV and the most modern video input that it has is DVI.
      I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
      01-27-2023, 08:19 PM
    • H34TO
      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
      by H34TO
      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
      06-17-2025, 07:17 AM
