TV Samsung UN75NU6900FXZA
  • Diah
    • Feb 2013
    • 6343
    802, 3,5,7,9 are the A13, so they look ok. 8 was 4.5 Diah.
    ok.. thx... its 9 not 8 as it look on my screen lol
    • Diah
      • Feb 2013
      • 6343
      then psu ok.... need to do following
      MB and BL connected..
      slide out the cable of oin 8 from the socket 802 ( isolated to be sure not do contact to any other or chassis ) and do jumper from pin 4 to pin 8... plug in wall and tell the result
      • alfredomfr1
        • Oct 2014
        • 318
        • usa
        Cable of pin 8 out, pin 4 and pin 8 connected, same result that post # 3.
        • Diah
          • Feb 2013
          • 6343
          need to inspect DC to DC on MB... but before that you need to be sure again about the panel if there issue ny disconnecting U ribbon cable not the 2 LVDS
          • alfredomfr1
            • Oct 2014
            • 318
            • usa
            Sorry for the delay I was out of the town.
            I disconnected the screen ribbon cables (no the LVDS) first one and then the other and finally both with the same result: STBY pin fluctuating between 3v and 7v
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              #26
              No red light on the front
                • 12076
                • U.S.
                #27
                Try some simple tests if you have not yet, with tv unplugged, check all the diodes and resistors on top of the powerboard.
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  #28
                  That was the first thing I did, this board has become a puzzle for me.
                  • Diah
                    • Feb 2013
                    • 6343
                    man yours set 76... on each side of the panel edge buffer boards which are under the speaker you will have U ribbon cable.,,, disconnect one a time see if u have boot complete
                      • 12076
                      • U.S.
                      #30
                      Report results of Diahs test, important to do tests in order, I think Diah starts with the simple things first, that's the best approach imo.
                      • alfredomfr1
                        • Oct 2014
                        • 318
                        • usa
                        #31
                        DM851C from left to right :
                        151.7v, 0v, 158.3v
                        DM852C from left to right:
                        158.8v, 302.1v, 150.5v​
                        DM851C is that 0v OK?
                        • alfredomfr1
                          • Oct 2014
                          • 318
                          • usa
                          #32
                          Diah I already did, post #25 and 26#
                          • Diah
                            • Feb 2013
                            • 6343
                            no you didn't... U ribbon see them here have access to them and disconnect one a time
                            • alfredomfr1
                              • Oct 2014
                              • 318
                              • usa
                              #34
                              Yes, I already did it
                              • alfredomfr1
                                • Oct 2014
                                • 318
                                • usa
                                #35
                                post #25 and #26
                                  • 12076
                                  • U.S.
                                  #36
                                  Can you post a good detailed picture of the bottom of the powerboard?
                                  • Diah
                                    • Feb 2013
                                    • 6343
                                    useless
                                      • 12076
                                      • U.S.
                                      #38
                                      So you did the u ribbons then, not just the ones going from mainboard to driverboard?
                                      • alfredomfr1
                                        • Oct 2014
                                        • 318
                                        • usa
                                        #39
                                          • 12076
                                          • U.S.
                                          #40
                                          Ok, I don't know for sure but it looks like the middle pin on DM851C isn't going to anything?
                                            09-07-2024, 05:50 AM
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
                                          • JSin21
                                            Compatibility of main boards between different variations of samsung MU6100
                                            by JSin21
                                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                            11-27-2023, 04:54 AM
                                            09-06-2024, 11:40 PM
