TV Samsung UN75NU6900FXZA
    Originally posted by nomoresonys View Post
    802, 3,5,7,9 are the A13, so they look ok. 8 was 4.5 Diah.
    ok.. thx... its 9 not 8 as it look on my screen lol
      then psu ok.... need to do following
      MB and BL connected..
      slide out the cable of oin 8 from the socket 802 ( isolated to be sure not do contact to any other or chassis ) and do jumper from pin 4 to pin 8... plug in wall and tell the result
        Cable of pin 8 out, pin 4 and pin 8 connected, same result that post # 3.
          need to inspect DC to DC on MB... but before that you need to be sure again about the panel if there issue ny disconnecting U ribbon cable not the 2 LVDS
            Sorry for the delay I was out of the town.
            I disconnected the screen ribbon cables (no the LVDS) first one and then the other and finally both with the same result: STBY pin fluctuating between 3v and 7v
              No red light on the front
                Try some simple tests if you have not yet, with tv unplugged, check all the diodes and resistors on top of the powerboard.
                  That was the first thing I did, this board has become a puzzle for me.
                    man yours set 76... on each side of the panel edge buffer boards which are under the speaker you will have U ribbon cable.,,, disconnect one a time see if u have boot complete
                      Report results of Diahs test, important to do tests in order, I think Diah starts with the simple things first, that's the best approach imo.
                        DM851C from left to right :
                        151.7v, 0v, 158.3v
                        DM852C from left to right:
                        158.8v, 302.1v, 150.5v
                        DM851C is that 0v OK?
                          Diah I already did, post #25 and 26#
                            no you didn't... U ribbon see them here have access to them and disconnect one a time
                              Yes, I already did it
                                post #25 and #26
                                  Can you post a good detailed picture of the bottom of the powerboard?
                                    useless
                                      So you did the u ribbons then, not just the ones going from mainboard to driverboard?
                                          Ok, I don't know for sure but it looks like the middle pin on DM851C isn't going to anything?
