TV Samsung UN75NU6900FXZA
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    LEDs TV work with the Power to Main Board cable disconnected.
    If the cable is connected red light no present, STBY pin oscillating.
    I replaced the Main Board 2 times with same result.
    Now the weird thing: With the TV connected and the LEDs lighting up , I connect back the cable to the Main Board, the TV turns off but the red LED light up and you can turn ON and OFF the TV working perfectly until you disconnect the power.
    When you disconnect the Power the TV return to the previous situation.
  • Diah
    • Feb 2013
    • 6376
    you are just tricking the T-CON protection section on MB to remain ON.
    in other words.. don't do this again... go down to the panel buffer boards you will have on each side at the middle U ribbon cable disconnect one a time and turn on normally see if the TV start
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      I've done this before, with any combination, the same result, the red LED off, TV can't power ON, Stby fluctuating between 3v and 7v, Main Capacitor 164v, same result with 3 main boards
      • Diah
        • Feb 2013
        • 6376
        in this case then yours PSU in questions... disconnect MB from it,,, and disconnect the BL from it too and plug in wall measure the V on the socket at any pins of A13V
        • Diah
          • Feb 2013
          • 6376
          blown cap !
          • lotas
            • Jan 2016
            • 4613
            • Russia
            No, it's the thermal paste that got in...
            • Diah
              • Feb 2013
              • 6376
              lol my eyes still strong... the cap in red circular are in question,, no pasta on it
              • lotas
                • Jan 2016
                • 4613
                • Russia
                Yes, just like the others...
                This is when thermal paste was applied to the transistors, those that are attached to the radiators, and the capacitors were stained with it.
                • Diah
                  • Feb 2013
                  • 6376
                  let say you are correct... then why they put thermal paste on them... its unusual at Samsung.... mean this caps are under load and heat.
                    • 12210
                    • U.S.
                    Looks like someone was just a slob and wiped the excess paste all over everything.
                      • 12210
                      • U.S.
                      Ok, so lets follow suggestions, isn't that why you come? Do as suggested in post # 4, report results here.
                      • R_J
                        • 9549
                        never mind
                        • alfredomfr1
                          • Oct 2014
                          • 318
                          • usa
                          No, is a light effect, cap is ok
                          • R_J
                            • 9549
                            That is NOT the caps I am talking about
                            • alfredomfr1
                              • Oct 2014
                              • 318
                              • usa
                              I will do the #4 advice tomorrow, thanks for all your effort, see you guys tomorrow.
                              • alfredomfr1
                                • Oct 2014
                                • 318
                                • usa
                                MB and BL disconnected
                                CNM802
                                1- 0.9v
                                2- 3.3v
                                3, 5, 7, 9- 12.85v
                                4- 3.3v
                                6- 3v
                                8- 4.5v
                                CH1- 301v
                                CH2- 0
                                CH3- 301v
                                CH4- 0
                                CH5- 0
                                CH6- 301v
                                Main Capacitors- 396v
                                DM851C
                                leg 1- 150v
                                leg 2- 0v
                                leg 3- 158v
                                DM852C
                                leg 1- 158v
                                leg 2- 302v
                                leg 3- 150v
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  CNM802
                                  1- 0.9v
                                  2- 3.3v
                                  3, 5, 7, 9- 12.85v
                                  4- 3.3v
                                  6- 3v
                                  8- 4.5v
                                  check again you may missed with pins NO.
                                  • alfredomfr1
                                    • Oct 2014
                                    • 318
                                    • usa
                                    pin 10, 11 and 12 are GND
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      man.. i remarked yours error with red color... pin 8 are Power_ON is it really 12.85V ?
                                        • 12210
                                        • U.S.
                                        802, 3,5,7,9 are the A13, so they look ok. 8 was 4.5 Diah.
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
                                          09-06-2024, 11:40 PM
