My first post
So I've been trying to troubleshoot my faulty Samsung D5520 LED 40" today. The issue I have is a constant black horizontal bar across the top of the screen. I think I narrowed it down to the T-CON board, the master or slave panel which connect to the T-CON board, the bonding of the 'tabs' under the metal frame or the LED panel itself. I couldn't get into the metal frame to test the bonding on the "tabs" as the screws holding in place wouldn't come out. They are soooo soft they just perished when I tried to get them out! #fail - this really annoyed me.
Just a quick question....... the black horizontal line appears from the top-left of the screen and fades out to the top-right of the screen. If I unplugged the right-hand side cable from the T-CON board and didn't remove the left-hand side cable I didn't get any picture at all, yet if I removed the left-hand side cable and kept the right-hand side cable in place I got half a picture on the right-hand side of the screen. I swapped the cables around to make sure that one of them wasn't faulty and the same happened....so it's not the cables. Could this be the T-CON board failing to give out a picture to the left-hand side of the screen?
I'm thinking it might be more related to the tabs that are hidden under the metal frame, because squeezing the top left hand side of the frame sometimes makes the black horizontal bar disappear. Does this suggest poor bonding of a "tab" in that position? However, I read that a fault with the bonding of the "tabs" usually gives a "flashing" effect whereas what my TV has is a more of a constant black bar, which again makes me think it's the T-CON board!
Does anyone have any advice - TCON board or tab bonding issue??
All the backlights on the LED panel work fine, which makes me think it isn't the panel itself.
Any help or suggestions would be great.
Great forum!!!
My first post
!!So I've been trying to troubleshoot my faulty Samsung D5520 LED 40" today. The issue I have is a constant black horizontal bar across the top of the screen. I think I narrowed it down to the T-CON board, the master or slave panel which connect to the T-CON board, the bonding of the 'tabs' under the metal frame or the LED panel itself. I couldn't get into the metal frame to test the bonding on the "tabs" as the screws holding in place wouldn't come out. They are soooo soft they just perished when I tried to get them out! #fail - this really annoyed me.
Great forum!!!
