Samsung power board bn44-00427A
  • Ashry
    • Aug 2024
    • 10
    • Egypt
    I have a problem with Samsung power supply board bn44-00427A.(I am testing with main board disconnected so the all voltage shall be generated)
    The standby voltage is ok 5.3 vdc
    The problem with resonance circuit feeding 13v DC and led driver ic 25600 has vcc 15.5 vdc and no gate output I replaced it with no change. So I think it is a protection feature.
    But when I remove the transformer (PD46B2-PM) the ic work and gate out give 6.2 vdc and MOSFETs supply 200 v to transformer terminal . Just put transformer back the same thing happened.
    I measured the transformer coils primary and secondary not shorted
    I connect only the primary side the same thing happened no output.
    I know the failure of transformer is rare.
    Also I can't find replacement one.
    ​​​​​​I searched for schematic diagram but I can't find matched one so I download most similar.
    ​​​Can anyone help???
  • lotas
    • Jan 2016
    • 4627
    • Russia
    BN44-00427A Schematic
    • Ashry
      • Aug 2024
      • 10
      • Egypt
      Thanks lotas
      I attached schematic for another model which describe IC25600 Circuit
      • jchd
        • May 2022
        • France
        That file doesn't seem to exist here anymore.
        Can you post it again please?
        • lotas
          • Jan 2016
          • 4627
          • Russia
          I can, here you go.
          • jchd
            • May 2022
            • France
            Thanks. Unfortunately I misread the file name. Just like the OP I'm after the BN44-00427A design. This one seems very hard to find. Do you know where I could get it?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
              09-07-2024, 05:50 AM
            • Nicktronic
              Samsung Power Supply Board BN44-00874F
              by Nicktronic
              Hey everyone,
              This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
              Anybody...
              03-17-2025, 06:20 AM
