JVC LT-47X579 Picture comes on and then off
  • mjm0086
    Rookie @ Work!
    • Feb 2014
    • 8
    Hello, all new to this forum but plan to be here for a long time.
    What I have is a JVC LT-47X579 that I purchased off Craigslist to start my new hobby for $30.00 well I got it home plugged it in and then at first it had just like a blue glow to it, so I cycled the unit off and then back on and seen the HDMI box come on it the top right corner I was excited....well I then took it to the living room and hooked it upto the HDMI from the DirecTV and boom it was working for about 4 to 5 minutes then the picture faded out and the sound stayed though then it came back and then back off again, so I powered down turned back on it came on then off but still had sound. So anyone have some ideas where to begin?
    After I solve this one I have another 32" Sharp Aquos issue as well....the fun is just beginning...lol many thanks in advance
    Also if anyone ever needs any HVAC (heating and cooling advice or parts, that is my main profession)
    Mark
  • Kilroys
    • Feb 2014
    • 70
    • Sweden
    Re: JVC LT-47X579 Picture comes on and then off
    After a little digging this is what I found.
    • mjm0086
      Rookie @ Work!
      • Feb 2014
      • 8
      I have picture though and then it goes away this service sheet seems to be if you have no picture at all
      • mjm0086
        Rookie @ Work!
        • Feb 2014
        • 8
        Any others have any ideas or
        Starting point
        • mjm0086
          Rookie @ Work!
          • Feb 2014
          • 8
          Bump for some more suggestions. Thank you.
          • mjm0086
            Rookie @ Work!
            • Feb 2014
            • 8
            Still looking for some help here, thanks in advance.
            • philliesfan30m
              • Aug 2013
              • 542
              first thing people are gonna want are pics of the back of the whole tv with the cover off and then individual pics of each of the boards. to add pics hit go to advanced and then close to the bottom hit manage attachments to add pics. if it is intermittent it could be a lot of thing. something loose,bad connection etc.
              • T30M31
                • Feb 2014
                • 58
                Can you post pictures of the boards?
                Have you done a visual inspection of the boards looking for bulging or leaking capacitors, overheated components, or other indications of failure?
                Have you checked the power supply voltages?
                Can you tell if the backlight is turning off when you lose video?
                Have you tried anything other than the HDMI input such as cable input, menu, etc.?
                • mjm0086
                  Rookie @ Work!
                  • Feb 2014
                  • 8
                  Thanks for the advice and will do this evening....
                  • mjm0086
                    Rookie @ Work!
                    • Feb 2014
                    • 8
                    No I have not before I tore into it wanted to make sure it wasn't something as a simple reset or some rookie mistake I was missing. But I can do this this evening as well. Thanks for the input.
                    • dronerat
                      Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                      by dronerat
                      Hi Guys,
                      This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                      PSU: L48S6 FHS BN44-00807D
                      T-Con: BN95-01937A
                      Panel: CY-GJ048HGLVLH
                      MB: NA (Currently as the TV is assembled and forgot to take picture)
                      As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                      It was sent to an authorized service for repairs and returned with the...
                      05-15-2020, 08:03 AM
                    • mugunthans
                      LG 47LB6500.ATR - No Picture/No Back light but has standby voltage
                      by mugunthans
                      My living room TV kaput after lighting storm along with Cable Set-top Box connected via HDMI-3.
                      So, with my little knowledge of electronics I thought of fix it by myself.
                      First, I searched forum for any case registered existing if anyone have same issue/symptom.
                      Found some few case near matching But not really the same !!!
                      Now decided to open a new thread.
                      Brand: LG
                      Model: 47LB6500.ATR
                      Panel: LC470DUH (FG)(P2)
                      Main Board: EAX65363904
                      04-23-2020, 12:53 AM
                    • jimjoe123
                      LCD TV Green/Pink screen problem
                      by jimjoe123
                      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                      Then each time...
                      02-23-2020, 01:29 AM
                    • betmen
                      Grundig 40VLE4421 - no picture
                      by betmen
                      I changed few leds on led background and tv works for about one year.
                      It is not much in use.Then stops working again, I checked leds on background, all are ok.
                      When I light up the screen with lamp there is a picture but background is not working and you can`t se the picture on the screen.
                      When I touch connector for led background with probes of backlight tester they light up and tester shows 108V. After that TV turn on normaly and picture is ok, backlight is working. After TV is turn of again backligt is not working, just on first turning on GRUNGDIG picture on boot is shown...
                      06-04-2022, 08:12 AM
                    • DXseekerMO
                      TCL 55US57 backlights, no picture.
                      by DXseekerMO
                      So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                      The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                      Power Supply, main and T-CON board are working.
                      Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                      Unhook FFC from left side...
                      09-18-2021, 03:56 PM
