lg ps8000 vertical lines
  • tonyuk
    • Feb 2014
    • 238
    hi guys been offerd this 60" tv lg ps8000 tv has vertical lines that move could this be fixed or do you think its the panel itself any help plz thanks again
    should also say the lines change in colour
    Re: lg ps8000 vertical lines
    90% panel...
    • johnboy1313
      • Nov 2012
      • 1959
      Post pictures.
      • tonyuk
        • Feb 2014
        • 238
        pics
          The lines move? Do they follow bright picture content.
          Probably not panel...
          Could be a Vsc or -Vy voltage problem, or a control board issue.
          • tonyuk
            • Feb 2014
            • 238
            yes tom the lines move dont realy see them on black screen ive up vs and va but no change ?
              Do NOT increase Va. You will fry the panel! Make sure it is set to stock rating. I would also leave Vs at stock setting, as the problem isn't likely to be caused by low/high Vs.
              I'd start by checking -Vy and +Vsc; if you need help with this post the LG Electronics PDP50K9##### (or similar) number which is written on the rear panel of the plasma screen.
              • tonyuk
                • Feb 2014
                • 238
                thanks tom PDP60H30001 i turn vs va up to what says on sticker
                  OK, I got the panel doc.
                  Check page 220 for Vs/Va
                  Check page 222 for -Vy/Vsc
                  Check page 226 for Vzbias
                  • tonyuk
                    • Feb 2014
                    • 238
                    thanks tom ill have a read
                    • tonyuk
                      • Feb 2014
                      • 238
                      done them tom now got this
                        Did you adjust them to match the panel sticker? What were they measuring before?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Looks like -Vy is increased too much. I'd jumper control board test patterns.
                          • tonyuk
                            • Feb 2014
                            • 238
                            they was 1v some 2 v out to low do you know if my spair board ebr54863601 would fit . looked on ebay and for same model theres diffrent part numbers for the ctrl
                              50PS3000 is a completely different model, with a different panel, so I would say no it won't work. In general you can't put 60" CTRL in 50" TV or vice versa because the drive waveforms are bad.
                              I'd try tweaking -Vy to get rid of the pink. Then focus on Vsc. What are your -Vy and Vsc supposed to be?
                              • tonyuk
                                • Feb 2014
                                • 238
                                well checked borad with my spair and found that the board numbers match but not the sicker number the one i gave you so fitted it and gues what
                                no vertical lines looks 90% better lol done the volts checks again with info you gave now just get green/ blues on light pictures ? but cant be seen on some dark pictures
                                  Well, it could be because 50" and 60" are different panels - pic of fault?
                                  • tonyuk
                                    • Feb 2014
                                    • 238
                                    if i adjust vy and vyc i can get rid of the green/blue ? and get clear pic ?
                                    will pic up in morning as in uk times is now 104am lol will also take pic of both boards for you like i said all number on the board do match just not sticker strange
                                    • tonyuk
                                      • Feb 2014
                                      • 238
                                      pic for you
                                      • tonyuk
                                        • Feb 2014
                                        • 238
                                        both boards check numbers sure should work
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • pni
                                          LG 49uf695v vertical coloured lines
                                          by pni
                                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                          11-14-2025, 03:15 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
