Sharp Aquos LC46D62U green led blinking
  • superg
    • Dec 2013
    • 58
    • Barbados
    I am now working on this set. When I plug it in the green led flashes steadily. I have a service manual but there is nothing that covers this. Thanks for your help.
  • superg
    • Dec 2013
    • 58
    • Barbados
    Re: Sharp Aquos LC46D62U green led blinking
    Update : I learnt today that I'm the third tech working on this set. The mainboard and power supply were replaced.Looks like some components burnt above c2720 on the AV input board. This link helped in getting it back on. http://www.helpowl.com/q/Sharp/LC52D...et-power/91890
      Might be the same as my LC-32DH66E
      http://www.youtube.com/watch?v=XDVY_tCTohk
      It had blinking or solid LED, no picture.
      • basil13
        • Feb 2014
        Is there a pattern to the blinking? Example--3 quick blinks, then a pause, then repeat? Is there an OPC light blinking as well or just the a power light?
        • olegeisler
          SHARP AQUOS LC-70LE836S only blinking - freebie
          by olegeisler
          Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
          Symptoms :
          When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
          A press on MENU as per the manual changes this to one short blink, one long and then repeats.
          Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
          As I see it mainboard has some kind of life, but does not...
          07-23-2022, 07:01 AM
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • jxrepman
          Asus X453MA won't turn on and green led light blinking
          by jxrepman
          Hi there,
          I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
          I have checked the charger and it is giving 19+ V
          I have disconnected the battery and pressed power button for 30 seconds.
          I tried another RAM stick.
          Tried disconnecting the keyboard and touchpad.
          Tried disconnecting the HDD and the wifi adapter.
          The problem persists.
          Hope you could help me out on this one. Thank you.
          12-14-2024, 06:40 AM
