lg p's 800 fuzzy picture plasma
    Re: lg p's 800 fuzzy picture plasma
    You just checked them.
    Could be a dried out startup cap, etc.
    • adamp91gvm
      • Jan 2014
      • 699
      Where are the starter caps on this board are they the bigger ones
        No - the smaller ones - startUP capacitors, they connect to the VCC pin of the controller chips (like that stand up one on the Samsung plasma you're doing.)
        • adamp91gvm
          • Jan 2014
          • 699
          Top middle or bottom
            Haven't a clue - you'd have to locate the controller chip - it's usually near the transformer(s). You can locate a controller IC by googling it's part#. I'd start with that 8 pin smd top left of the transformer.
            • adamp91gvm
              • Jan 2014
              • 699
              #26
              I have found ic 402 and the two next to each other are ic602 and ic601
              • adamp91gvm
                • Jan 2014
                • 699
                #27
                Should I be getting 17v on one of the legs of ic 402
                • adamp91gvm
                  • Jan 2014
                  • 699
                  #28
                  Just ordered a new y sustain so fingers crossed
                  • adamp91gvm
                    • Jan 2014
                    • 699
                    #29
                    Just got a new y sus and it's exactly the same any ideas
                      Check -Vy/Vsc. Still bad?
                      Maybe try without one or other buffer.
                      • adamp91gvm
                        • Jan 2014
                        • 699
                        #31
                        Yer still going up and down with either buffer in or out
                          You probably got a bad board then. Was it from a reputable source...?
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            #33
                            Off eBay he said it works and it's tested has good feed back
                              I can't see anything but a bad Y-sustain causing your problem, unless the buffers are damaging it. Due to the picture being OK aside from fuzzyness this seems unlikely. Not sure what to suggest.
                              99% of sellers don't test the boards because they can't. You'd have to have a spare panel to fit all the boards to and check them. The few exceptions are US sellers such as shopjimmy who do check each board, apparently.
                              • adamp91gvm
                                • Jan 2014
                                • 699
                                #35
                                Yer its just a bad pic with a pink mark if I turn vs up it goes to a nice pic but goes off after a few seconds
                                  That will occur if you increase Vs too high, power supply can only provide so much current.
                                  • adamp91gvm
                                    • Jan 2014
                                    • 699
                                    #37
                                    The pic is good if I turn it up from 194 too 205 but can it stay there or will it damage it
                                      Do -Vy and Vsc stabilise when you do this? What is the rating on the panel for Vs and Va?
                                      • KYBOSH
                                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                        by KYBOSH
                                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                        No picture but you hear the TV static (white noise) playing loud and clear.
                                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                        But it seems they didn't get too far and just left it.
                                        When I first took a look I was amazed at how pristine the inside looked.
                                        Its as if the TV had been in a time capsule.
                                        Caps looked like they were just pulled off the self.
                                        Copper coils had no sign of corrosion on...
                                        02-01-2023, 11:10 PM
                                      • KYBOSH
                                        Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                        by KYBOSH
                                        Saved this beast from the landfill this weekend.
                                        Manfactured July 2013 in Mexico.
                                        I love working on plasma TVs.
                                        Its been a while but I was lucky enough to find 2 this week.
                                        The TV powers on and stays on but no picture. Havent checked for sound yet.
                                        No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                        Will start troubleshooting tonight.
                                        10-17-2024, 01:17 PM
                                      • Tr0ll
                                        by Tr0ll
                                        Original T-con:
                                        First replacement T-con:
                                        10-07-2023, 07:48 PM
                                      • JJAAMM
                                        by JJAAMM
                                        Problem
                                        07-06-2023, 06:01 AM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
