Samsung QLED QN75Q8FNBFXZA inverted/negative color
This topic has been answered.
  • j879
    • Jul 2024
    • 14
    • US
    hi guys,
    My 5 years old SAMSUNG QLED got color inverted somehow. I have tried reset, replace mainboard as well as the driver board without luck. The issue must be on the circuit on panel skinny board or so. For this model I could not find the dedicate T-con board so AS15 replacement is not applicable..
    I have upload the pictures
    Maybe I should measure the gamma voltage but I couldn't find the right place.
    Any idea would be appreciated.
  • Answer selected by j879 at 07-12-2024, 09:14 PM.
    lotas
    • Jan 2016
    • 4594
    • Russia
    The problem may be in these protective diode assemblies (leakage, breakdown of one diode, short circuit to ground...) and in my opinion your resistor turned black because of them.
    And check, if something starts to heat up too much, then there is a problem there.​
    • lotas
      • Jan 2016
      • 4594
      • Russia
        • 12181
        • U.S.
        So check that dark resistor, as suggested see if any of those diode packs are hotter than the others, if so remove it and recheck tv.
        • j879
          • Jul 2024
          • 14
          • US
          You are absolutely right. I use an infrared temperature gun measured the the right side as you mentioned with dark resistor, the temperature of the resistors are 10C higher than the opposite side.
          Then I disconnect the ribbon cable to the overheated skinny board the color turns back normal without 1/4 of the display.
          I guess next step is to find out the broken resistor or diodes. The temperature of the protective diode assemblies are normal compare to the other side. I'm going to remove one by one and see what happens.
          Do you know whats the model number of the diodes assemblies?
          Many thanks both of you!
          • j879
            • Jul 2024
            • 14
            • US
            Got 2 more closer pictures now I can see the part/model number. Shall I remove the 6514Ps ?
            • lotas
              • Jan 2016
              • 4594
              • Russia
              https://www.badcaps.net/forum/troubl...ot-issue/page2
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                is still there someone that tries to repair a thing without swapping boards randomly?
                i understand the MB but the Led control board...
                anyway i don't understand the advice about diodes / resistor, those are not responsible of the colour of the pixels, my attention is on the serial flash on the right side panel pcb, is that the main tcon data? since tcon today are integrated to mb then needs only a different data for different panel and that's why data is on the panel, for me.. in other threads someone readed that mem and found it empty, that's strange, i find no reason to mount an empty flash.. it is not for storing errors cause it would be enough a standard eprom.. eventually try putting an 1kohm pulldown resistor between its clock pin and gground and test..
                • lotas
                  • Jan 2016
                  • 4594
                  • Russia
                  Check the resistance on these legs relative to the ground with a multimeter, if it is low, remove it.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4326
                    • Italy - Milan
                    multi diodes are pertinence of clock signals, neighter clock signals nor voltages for line selection can alter the colours, especially let it being negative..
                      • 12181
                      • U.S.
                      Its been a while, didn't we see in the past a bad diode pack presenting a display like this?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4326
                        • Italy - Milan
                        I forgot that MB contains Tcon software in a serial flash, but the one on panel what is? Are source cof more complex than before and stores data on it?
                        • lotas
                          • Jan 2016
                          • 4594
                          • Russia
                          It contains corrections for dead pixels of the panel; if there are no dead pixels in the panel, then the spi flash will be empty.
                          This is entered at the manufacturer's factory.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4326
                            • Italy - Milan
                            thanks
                            • j879
                              • Jul 2024
                              • 14
                              • US
                              ok, I removed 6514Ps​ one by one starting from D001 to D003 without luck..
                              blacked resistor remains untouchable.
                              Then I tried to tape out the ribbon cable from outermost side for 5 or 6 pins it fix the issue with minor missing interlaced lines.
                              Now the temperature went back to normal for the resistor and caps....
                              • lotas
                                • Jan 2016
                                • 4594
                                • Russia
                                Tin the contact pads well using flux so that they do not short out each other.
                                And check this resistor with a multimeter, it should show 100 Ohm.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4326
                                  • Italy - Milan
                                  My bet is that the resistor heaten due to a bad cap, check every one in ohm mode, you also cool them one by one touching with a plastic wrapped ice cube..
                                  • j879
                                    • Jul 2024
                                    • 14
                                    • US
                                    Cleanup the residue still the same
                                    • Diah
                                      • Feb 2013
                                      • 6365
                                      there are no bet over electronic repairs,, ... who like betting go play lotto .. don't play with users TV
                                      i hope you didn't damaged the 3 ESD diode... if not put them back... we have here threat best masking method a person from japan... he did mask only 2 clk and have perfect picture just one thin line... this where no one can do against it when gate transistor at panel shorted
                                        • 12181
                                        • U.S.
                                        Those diode packs aren't that important, they do cause more problems than they prevent.
                                        • Diah
                                          • Feb 2013
                                          • 6365
                                          sorry friends... this is wrong.. they are like cut circuit when panel API changed or from HDR to HDR+ they are watch dog to the gate transistor of panel... but dome time they are dummy and the gate shorted... but this doesn't men they are troublesome.
                                            Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                            This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                            09-07-2024, 12:10 AM
                                            09-07-2024, 05:50 AM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • Batata
                                            Samsung QLED GQ50Q67TGU turns on and off
                                            by Batata
                                            Hello everybody,
                                            my TV has a problem. It keeps turning on and off. The speakers are still working, and I hooked up the TV to my PC, and it recognizes it as a Samsung device. I am able to get a stable backlight when I disconnect the cable(I believe it is called the LVDS cable) that connects the left lower board (which is connected to the "main board") and the right lower board. I have tried a taping method I saw on YouTube, where the CLK cables are taped off. In fact, I proceeded to figure out which pin I have to tape off in order to get a stable backlight. It doesn't matter...
                                            10-14-2024, 03:45 AM
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
