Samsung LNT4661FX/XAA distorted middle of screen
  • freakaftr8
    • Oct 2012
    • 3743
    this is an interesting one previous owner said there is something wrong with the panel stated by the repair shop well I can tell you that's not the panel as when I first turn the TV on with a black screen the menu came up perfect but as soon as I went to a snowy screen on air this popped up the menu still tries to come up in the foreground you can see the no signal pop up from here and there between the distortion so it definitely looks like a mainboard fault or possibly the power supply giving off wrong voltage. Any thoughts before I tear into it?
    http://i845.photobucket.com/albums/a...ps1bfbd9fd.jpg
    Re: Samsung LNT4661FX/XAA distorted middle of screen
    Main board - RAM would be my bet. Some Samsungs have option for testing beforeDDR and afterDDR for narrowing fault down...
    Or if it has a motion FRC on T-con could be that (motion FRC is for 100/120Hz feature)
    • freakaftr8
      • Oct 2012
      • 3743
      Which mainboard ram would I be looking at? in the service menu the only option for ram check is Under checksum and that has 0000 and when I initialize it says D652. Does that mean anything?
      Here's the mainboard.
      http://i845.photobucket.com/albums/a...ps1697278d.png
        I wouldn't have the faintest clue, sorry.
        • freakaftr8
          • Oct 2012
          • 3743
          any chance the firmware is corrupt? I cannot seem to locate the firmware in Samsung's site.
          Thought I would give it a shot before I try to find a replacement or part the thing out.
          Funny, on accident I initialized the SW upgrade thru USB even though there is no USB in it. at the end of the 30 second scan the screen went wonky.
          Definitely a glitch on the mainboard. Tcon on ths unit is very basic, and it was manufactured mid 2007, wad there even a 120hz panel then?
            I would be surprised if corrupted firmware would cause this.I'd try heating/cooling stuff, maybe you can find the source of the fault as it sounds temperature dependent.
            • freakaftr8
              • Oct 2012
              • 3743
              Heating and cooling does not make.a difference on this one. Its stubborn. Actually out of the box cold it does it.
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
              • Kiberge
                Samsung LH82QENELGC/EN Help needed - Static line on screen
                by Kiberge
                HI guys!
                I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                04-22-2024, 11:28 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • arbitarytwist
                Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                by arbitarytwist
                Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                03-01-2025, 01:16 PM
