Lg 50pq30
  • pposey
    • Oct 2012
    • 60
    Lg 50pq30
    Hi. Let me just start with what boards i have replaced. I have replaced the y-sus, z-sus, control board and lower buffer board.
    I have sound but no picture unless i remove the bottom buffer board completely. Then on the top half of the tv i have picture but has vertical black lines across it but still see the static screen in the back. So thats when i bought the new buffer board but when i put the new one in there still wasnt a picture but has sound. I have no clue what it could be. Im thinking something on the bottom part of the y-sus where it plugs it but i may be completely wrong. Thank you for your help!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Lg 50pq30
    Your upper buffer board may in fact be toast. The lower will not display a proper picture without the upper installed as the data has to go thru the upper to get to the lower.
    • pposey
      • Oct 2012
      • 60
      Re: Lg 50pq30
      wow. so i bought the wrong buffer, that sucks. Thanks for the quick reply. I guess ill buy the upper. If that doesnt work i guess ill part it out. Thanks again for your help.
      • freakaftr8
        • Oct 2012
        • 3743
        Re: Lg 50pq30
        Scratch that. Your lower is bad I meant. Did you buy the lower new or used off eBay that was stated as tested?
        • pposey
          • Oct 2012
          • 60
          Re: Lg 50pq30
          Bought it out of a new tv that the screen was damaged during shipping.
          • pposey
            • Oct 2012
            • 60
            Re: Lg 50pq30
            You think it is the y-board again or is it something else? Anything i can test?
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Re: Lg 50pq30
              You can test for shorts on the buffer board similar to the Samsung buffers. If you bought it from a panel with the cracked screen chances are the buffer may be bad. Buffers usually go bad once screen is cracked and power goes through it.
              • pposey
                • Oct 2012
                • 60
                Re: Lg 50pq30
                Thanks for the quick reply. I tested for shorts on both the original buffer board and the one i bought. Niether one of them had shorts. Does that count them out as being bad or can they still be bad?
                • pposey
                  • Oct 2012
                  • 60
                  Re: Lg 50pq30
                  Anybody else have a idea on whats going on or had the same problem? i really dont want to part this out if i dont have too.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ermals
                    Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                    by ermals
                    Hi all!
                    I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                    1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                    2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                    3. I've checked voltages...
                    08-01-2022, 10:35 AM
