Samsung ln52a650 power on off with starting sound and clicking
  • X246
    • Feb 2014
    • 7
    • Usa
    When the tv power is plugged, it plays the power on sound, then a clicking sound, power on sound, and clicking sound... Typical issue for a samsung tv. It never stays power on.
    All capacitors look fine. When the t-con board is disconnected from the main board, it seems to stay on. After the power on sound, no clicking, but the screen is black.
    Does this mean the tcon board is the problem?
  • X246
    • Feb 2014
    • 7
    • Usa
    Re: Samsung ln52a650 power on off with starting sound and clicking
    I can see the back light stays on when the tcon board is disconnected.
      Good clear pictures of the boards, especially the T-CON.
      Check the SMD fuse on the T-CON board.
      • X246
        • Feb 2014
        • 7
        • Usa
        Thanks Budm. Please see the pictures.
        A couple days ago I replaced two 1000uf capacitors on the power board even though it did not show any bulge. The symptom is the same as before they were replaced.
        • X246
          • Feb 2014
          • 7
          • Usa
          The tv is working now. I don't know why. I just disconnected and reconnected the tcon board, took the tcon board cover and the main board cover off. Two components (one on top and another on the bottom) of the tcon board are in contact with some patches and they are oily. And I accidently removed some oil off. Probably I should do a factory reset. Still mysterious. Any suggestions what caused the problem?
          • Dang
            • Aug 2013
            • 440
            Those oily patches are for cooling I believe, I wouldn't worry about a little lost oil, as to the cause of your issue, maybe a bad ground resolved by simply moving things around, I don't know but glad it's working again, fingers crossed it stays that way.
            • tibimakai
              • Jan 2012
              • 3680
              It seems like somebody already replaced some of the capacitors(blue ones). They may not be the right ones.
              Most likely the problem will come back.
              • X246
                • Feb 2014
                • 7
                • Usa
                Thanks Dang and Tibimakai. Yes I replaced the two capacitor even though they didn't show problems (please see my previous post). I would like to know what caused it so I can avoid it happening again.
                  The capacitors there look like generic Lelon, they're probably worse than the original Samsung specified parts (which aren't much good to start with...)
                  • X246
                    • Feb 2014
                    • 7
                    • Usa
                    Thanks Tom66. Yes that was I was wondering about. I got them from Radioshack but they are 35v. I'll replace them if the tv can work for a while.
                      I would buy Panasonic FM, FR, FC from Digikey for lifespan reasons.
                      • tvsteve2
                        • Aug 2014
                        • 25
                        • usa
                        I have found that the gray heat compound (they call chocolate) sometimes gets slimey and that broken down chemical can be resistive and short out parts! I found it first in Sharps, then RCA CTC169 Pip Modules, Mits modules and samsungs! Replace all the compound with fresh DRY stuff after washing the effected chips with Acetone or 91% alcohol.
                        • B0r1s
                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                          by B0r1s
                          PSU - BN44-00878A
                          Symptoms:
                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                          A weak clicking sound was coming from the transformer.
                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                          Progress:
                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                          01-17-2023, 04:58 PM
                        • Sisko
                          Onkyo-593 No power and now clicking sound
                          by Sisko
                          Hi all!!
                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                          10-03-2025, 02:18 PM
                          09-07-2024, 05:50 AM
                        • slimmy182
                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                          by slimmy182
                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                          Looking on google I found this:...
                          01-14-2023, 11:55 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
