Panasonic TH-50PX8EA Black screen, only relay clicks
  • Rensiee
    • Jun 2024
    • Netherlands
    I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
    I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
    When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
    I have measured the voltage in the VSUS line, which shows around 1 V and goes up to around 2 V, but won't go any higher.
    I do not have a lot of experience with TV boards, so I will not know everything about the TV I am afraid.
    Could someone help me with this?
    The link to the old thread is as follows: https://www.badcaps.net/forum/troubl...ck-no-blinking
    Thank you in advance
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Chrissygizmo
    Panasonic TX-48CX350B backlights but white screen , blank screen
    by Chrissygizmo
    Hi all, I’ve got a problem I hope someone can help me fixi.
    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
    01-11-2025, 03:18 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • thstuff
    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
    by thstuff
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
    12-26-2024, 09:10 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
