Before the tv wouldn't turn on then back off after a few seconds. I hooked up a little ribbon cable between the 2 audio boards (pd1) which i thought was insignificant. However, now with the ribbon connected the tv led stays solid green. Also now the screen does not light up at all.
Voltages: There is a 13 pin connector rail. I get -1.5V, 1.2V on 2 pins. i get 5.96 on 2 pins. (As soon as i put the meter on, it shows around 9-10v for a split second then continuous 5.96.) I also show 4.55 for 2 other pins on the same rail.
I have 3 other rails with yellow, black, and white wires. 1 of each on each rail of the 3 rails. on the middle rail I get 3.3V on the white wire.
On the rails to the sustain boards I get .9V on red and .5V on white.
these voltages are the same whether in standby or power on.
Any Ideas?
Thank you.
Any Ideas?
Thank you.
