Panasonic TH-42PZ80U
  • n3lka
    • Jan 2014
    • 84
    Hello everyone, just wanted to pass on that I had a Panasonic 42" Plasma that had the half screen issue. I read another post out here that a 46" was doing the same thing, and that it may be related to re-seating of the cables going to the D board.
    Well, I re-seated all the cables to and from the D board, and it worked. Just wanted to pass it on in case someone else had the issue. I've had it on testing it for a few hours and tapped it at intervals to make sure the problem hasn't returned.
    So far so good. Once again, thanks to the forums and all the knowledge.
    Brian
    Re: Panasonic TH-42PZ80U
    Nice one. My 46" (probably the post you're referring to) has been working for over 9 months now with that fix.
    • n3lka
      • Jan 2014
      • 84
      I think it was Tom66. I have the tv on watching a golf game. I don't like golf, it's the only off air channel I get good reception on....lol.
      I test with a clothes hanger antenna, I don't want to disconnect my cable box each time.
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • mrmouse17
        thinkpad p14s gen4 pass bios
        by mrmouse17
        Can someone help me remove bios password thanks....
        10-23-2025, 01:26 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
