Strange Lines Phillips 32'' 32pfl3506/f7
  • rikrikrik13
    • May 2013
    • 44
    Someone gave me this tv for free. She said she received it by UPS and the tv worked for 1 week then start to show lines everywhere (unable tu see the picture, picture was only lines of different color, mostly white)
    I opened up and the connector on the mainboard/t-con was not clipped.
    Now the tv work but I still have some very lite lines on the right side of the screen.
    Can someone help me?
    Sorry for the pictures its very hard to see
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: Strange Lines Phillips 32'' 32pfl3506/f7
    I would try cleaning and reseat the tcon connectors again until it goes away, if it still doesn't work then its probably the panel going bad.
    • patrax
      • Feb 2014
      • 33
      Check all your ribbon cables going to inverter too. While your in there clean out all dust and dirt etc. Look for anything oozing fluid and make sure all connections are tight and solid. If it's tab bonds it will get worse fast. Buy a can of good fast drying contact cleaner it works wonders on ribbon cables.I use a pencil eraser too with good results. If you can twist the outer frame of the set and they disappear it's most certainly tab bonds failing .Some sets can have the repair work for a long time some not. Believe me it's a time consuming job repairing bonds.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Rubenlily
        Samsung QE50Q67TAU - horizontal lines
        by Rubenlily
        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
        I'm no expert but I've done the tape...
        08-16-2023, 01:12 PM
      • ggil44
        Sony XBR-65X750D Horizontal lines bottom of screen
        by ggil44
        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
        05-30-2023, 07:51 PM
