LG 65G3PSA won't turn on
  • charlesjami
    • Jun 2024
    My TV has red light. When I press the power button, it clicks on time and then goes back to standby red light.
    Is there anyone having the same issue? How to solve it?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    What type of screen has ? Need PSB and screen stand alone test
    • Noah Glasse
      LG 50PK590 - three clicks and steady red light, won't turn on.
      by Noah Glasse
      I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
      I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
      02-24-2025, 07:23 AM
    • popzeggey
      Dell Precision 7520 power issue
      by popzeggey
      Hello, I have the similar problem. My Dell Precision 7520 doesn't turn on with only battery. Below are the various scenarios and its symptoms
      1. With only battery, the laptop turns on but no display and shuts down after few seconds
      2. With battery and charger plugged in, the battery light comes on. But pressing the power button does nothing and laptop refuses to turn on. However, the battery led light blinks every 17seconds from when the charger is plugged in with or without battery. So whether the battery is inserted or not, the battery led light will turn when charger...
      06-07-2024, 09:23 PM
    • Adogabriel100
      Macbook pro A1278 820-2936 No light/turn on
      by Adogabriel100
      Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
      History:
      this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
      A month later comes back again and has the actual problem (no green/orange light and dont turn on)
      The macbook can turn on with only the battery connected but in fact, dosent charge.
      Voltajes:
      PP3V42_G3H = 3.3v
      PPBUS_G3H = 12.2V
      PM_PWRBTN_L...
      06-28-2023, 07:41 PM
    • Woodsworth
      PS3 CECHC03 60GB YLOD Troubleshooting
      by Woodsworth
      I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
      START
      Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
      03-19-2024, 07:58 AM
    • dionzarek
      PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
      by dionzarek
      Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
      I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
      When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
      Any help to where should I check on or suggestion would be very appreciated....
      02-08-2025, 11:00 PM
