LG 65UQ7050ZUD No Picture Backlight On
  • ChattFix
    • Oct 2021
    • 79
    • US
    Hey everyone, I have an LG 65uq7050zud with a black picture but backlight is on. I tested the measurements from the PSU and they check out. I can’t find any service manual so I’m suspecting the main board. Any advice before I replace the board? Found them for around $60
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Just with experience I would be suspect of the panel. Did you try disc each side of ribbon cable to get 1/2 or 3/4 picture yet? Or tape any of the ribbon pins just to test to see? Alot of lgs I get in America are bad because of panel issues with same symptoms you talk about.
    • ChattFix
      • Oct 2021
      • 79
      • US
      I checked the panel by removing the left and right side ribbon and still didn’t get a picture. I’m also not getting any audio. A weird thing I notice is when I turn the tv off I hear a clicking sound coming from the main board. Near the main IC. I uploaded a video of it.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Just removing each side doesn't necessarily work sometimes, continue on with tape on both sides covering like 10 pins at a time. Take a couple minutes and check that.
        • Diah
          • Feb 2013
          • 6565
          SHORT OR CUT of VCC 3 V ON PANEL BOARDS
          • ChattFix
            • Oct 2021
            • 79
            • US
            I’ll do the tape tonight!
            • ChattFix
              • Oct 2021
              • 79
              • US
              So I looked at where the diodes are on the board and noticed ribbon 1 has them all. I placed tape on maybe 10-15 just to give it a shot and the picture is perfect. I’m kinda confused because I read how this should degrade the picture or lose potential colors?
              Should I just leave it and call it fixed until it fails?
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                If you go YouTube and watch screen test video ( type that) and look and see if there is lines or discoloration. But probably panel is shorted somehow.
                • ChattFix
                  • Oct 2021
                  • 79
                  • US
                  So it seems I am missing some horizontal lines. Should I start trimming the tape to see how good I can get it?
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    Up to you. But hey, saved ya $60 lol.
                    • ChattFix
                      • Oct 2021
                      • 79
                      • US
                      Haha exactly. I put it back together and called it a day. How long do you think it will last?
                      • EazyBone
                        • Jun 2023
                        • 1362
                        • United states
                        You never know. My guess is 6mo
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • Patrick501
                          Philips 55PUS6704 no picture, backlight ok
                          by Patrick501
                          I'd like to repair a Philips 55PUS6704.
                          It turns on and you can see the backlight, hear the sound but no picture.
                          When I disconnect one of the T-con cables, half of the screen turns white.
                          right cable disconnected= right side white
                          left cable disconnected= left side white
                          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                          Also you can notice one single...
                          11-12-2025, 08:46 AM
