Protron PLTV-32M
+ More Options
Posts
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Protron PLTV-32M
    Got this into my shop today. Set has power and comes on but the right half of the screen has a shadow or showing a little darker than the left side. Audio is good and all other functions seem to be working. I am thinking inverter board problem. Please help.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Protron PLTV-32M
    Check all the cables on the TCON are firmly in place - perhaps remove clean and refit?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Thanks. will try that. I checked caps. etc and all seem to be within a reasonable range.
      Doyou know whwer I could locate a Service manual. I tried the internet and read that the manufacturers are no longer in business....This set has some really wonderful features
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK. So I cleaned all connector cables and refitted them....AHH YES!! That solved the problem...Thasnks SELLDOOR for helping me out here.
        Regards.
        • Use2bavolvo
          Bad Caps affect on time / clock functions
          by Use2bavolvo
          can someone please help elaborate if a bad cap will affect time / clock functions. My fancy coffee machine has a preset pour for espressos's all of the presets are way out of wack what use to be 25 seconds is now 12.
          I am about to replace the psu caps but need some guidance if a bad cap would slow down or speed up clock functions?
          02-13-2023, 06:59 PM
        • kalemaroni
          MAG274QRF-QD 27" gaming monitor half backlight shadow
          by kalemaroni
          A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
          04-23-2024, 03:52 PM
        • Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
          by Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
          03-15-2024, 09:37 AM
        • myth77
          Laptop lcd shadow on the low right corner
          by myth77
          Today i received laptop that has fallen to ground...and was not turning on...i manage to repair it but it is now powering but with shadow (dim backlight) in the lower right corner. It is not broken...and i can see the screen...its just like backlight is not working or semi working in that part. Its not lcd cable problem, that i checked.
          I dont know can that be fixed? I am not expirienced with screen repair...Thinking maybe is some led from backlight gone bad...then again maybe its panel or flex cable!? Anyone had same issue?
          03-11-2023, 01:59 PM
        • Watson306
          6 Red Blinking lights (left side darker) on Sony KD-49XE8396
          by Watson306
          I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
          I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
          I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
          Many Thanks in advance.
          11-01-2022, 05:33 AM
