E-motion tv backlight flashes then off
  • wreksta
    • Aug 2013
    • 508
    • england
    Hi all just received this set it's working with no no backlight as I have sound etc and shining torch at screen I can see the image
    Tested all voltages from psi and all test correct
    But don't know how to test the inverter lol
    It's a ssi400 14ao1
    TV is emotion
    I know there is plenty of inverters on ebay but would like to fix this one any ideas what to test please
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: E-motion tv backlight flashes then off
    Put up a good clear picture of the front and back of the inverter board or section with the inverter transformers on.
      I'd check PSU 24V. Is this one of those crappy 17PW25-4 PSUs? I have one of those PSUs with over a volt P-P ripple on 24V. You can see the noise on the inverter output - bars rolling down the panel - if you look carefully. Crazy... It's possible the output could go further out of control causing this fault.
      • wreksta
        • Aug 2013
        • 508
        • england
        All my voltages are correct and steady tom
        the screen dont flicker or anything just no backlight ill take photos of board tomorrow but is there any fault finding tips to aid me
        cheers
          I believe the inverters for these are very cheaply available it will be the inverter, bulbs or main board. Unlikely to be the main board, you can eliminate that by checking BL ON/OFF signal. Inverter failure is most common but bulbs can fail too.
          • wreksta
            • Aug 2013
            • 508
            • england
            Going to replace the inverter will update when I get it
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Dont you even want to test it or has it tested bad
              • wreksta
                • Aug 2013
                • 508
                • england
                New inverter came still same fault I have a connector on the main board
                its the inverter connector it only has 4.7v and 2v and 2 ground
                the mainboard is cv306h-a-11
                Any ideas how to test or what the connector voltaged should be
                  Those voltages sound about right to me. I'd suspect bulbs in the panel or a defective inverter.
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                    Right tom ok second inverter same fault thing is only half the bulb lights on each tube
                    then all light dies
                      Could be a short to ground/arcing inside the panel; you'd have to take it apart to be sure
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        Took it all apart mate and cant find problem any ideas im going to recheck all voltsges now
                        where should I be looking for this arcing I have screen so can check anywhere
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          All voltages from power board all to spec so problem to me lies with mainboard anyway to jump the backlight on tom
                            Probably not. If your 2V & 4.7V are OK and steady (after B/L goes out) then the main board is A-OK.
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              solved
                              thanks for all the help
                              full set of ccfls from an 40"Samsung solved it
                                Can you see where bad CCFL(s) may have been?
                                • thetonywarren
                                  TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                  by thetonywarren
                                  I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                  04-23-2025, 10:48 AM
                                • DanPoka
                                  by DanPoka
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
                                • marce002
                                  Test dusplay "backlight only" A1297 macbook pro 2010
                                  by marce002
                                  Hi
                                  I have image but no backlight. Fuse is blown. I think the display is faulty or cable lvds.. but not shorted last 3 pins in connector to GND
                                  .. Can I test the screen backlight only unplugged from motherboard with 32v at those pins? (Expecting to see a backlight only)?
                                  10-07-2021, 06:31 PM
                                • Ancient1
                                  How to Test : Bad Backlight Driver OR Faulty_Strip
                                  by Ancient1
                                  Hi
                                  Its a "dumb" question , and an answer probably available somewhere ..
                                  Assume no Backlight Tester or exposed Strips , PSU has V/A Outputs Table.
                                  This transforms the question to :
                                  How to Test the Driver in uncovered TV ?
                                  Thx
                                  01-01-2023, 05:05 AM
