I'm looking to buy a replacement tuner board for a Vizio P50HDTV10A. I see that the Vizio 3646-0012-0190 Tuner Board 0171-1472-0355 which is for a different model looks identical but the flash device has a different label. Does anyone have experience with these as being interchangeable?
Vizio Tuner Cards DTV
Re: Vizio Tuner Cards DTV
I replaced a 3646-0012-0190 (GV46L LCD) with a 3850-0012-0187 (P50HDTV10A Plasma) with no ill effects. -
Thanks for that info Cliff.. I have 3 of the 187's that are not working. When I try to bring up the menu when the input is selecting DTV, the menu doesn't come up and the TV hangs... I sure would like to know what's causing it. All the voltage regulators are running fine on all three boards. Must be one of the ASIC's or the flash parts..Comment
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by DXseekerMOI can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
