JVC LT40X887 BOOBYTRAP'd HDMI Reset Needed
  • Coshelectronics
    • Aug 2013
    • 6
    • usa
    Here's a quick rundown, I've done tons of research on this but haven't found the answer I need yet. So I put it to you guys to see if you may have an answer for me.
    I have a JVC LT40X887 TV that had an issue with the power supply and needed the transformer reflowed. So unfortunately I tested it with the back off, and you guessed it. I was booby'd. So now of course every thing is all buttoned up and the TV is fixed but, you guessed it, HDMI's aren't working. So I researched and found I need to reset the hdmi's via self check in the service menu. Only problem is I don't have the original remote.
    So my questions:
    Do I have to have the original remote to access the service menu or can this be done via the button on the tv
    Or is there a way to reset this via jumpering pins on the board itself.
    Any help will be greatly appreciated, thanks in advance.
  • RON_CET
    • 217
    Re: JVC LT40X887 BOOBYTRAP'd HDMI Reset Needed
    Yes you will need the Original JVC remote attached is the procedure
    Ron Driver,BSEE,CET,ISCET,NESDA
    • Coshelectronics
      • Aug 2013
      • 6
      • usa
      Ok thank you, was afraid of that. Guess I'll have to find an oem remote
      • sheffieldyorky
        ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
        by sheffieldyorky
        Hey there people
        While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
        This is what I tried, but not in any order.
        Google
        YouTube
        BIOS
        Command Prompt (administrator privileges)
        On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
        10-25-2025, 02:22 AM
      • cstout
        DeLonghi AC Remote only accepts 3V
        by cstout
        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
        I can't find any schematics...
        06-03-2024, 03:53 PM
      • jemnis
        Lenovo x1 carbon DX120 NM-B141 rev 1.0 Bios RESET PASSWORD Needed
        by jemnis
        I NEED CLEAN BIOS
        P/L/:SL10P9806
        02-25-2024, 07:55 AM
      • Mc_Millian
        Toshiba 50lf711u20 fire tv remote not pairing
        by Mc_Millian
        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
        The Tv model number is: 50lf711u20 Rev B.
        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
        I've tried 3 different remotes which should be fully compatible with this TV.
        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
        The power button, along with the volume,back,select, and directional...
        04-07-2022, 12:15 PM
      • Chrissygizmo
        Panasonic tx-40cx400b universal remote code needed
        by Chrissygizmo
        Hi all
        Just a quick question...
        Does anyone know the actual "ONE FOR ALL" universal remote code for a Panasonic TX-40CX400B?
        I have downloaded the manual for it but the tv doesn't do anything. I can get it to power off when using some of the codes but no other buttons work , it won't even turn back on with the remote unless it's immediately after switching off 🤯 ...
        Thanks...
        08-29-2021, 08:02 PM
