Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
  • E--Man
    • Oct 2017
    • 27
    Hi All,
    Thanks for reading. Based on the interesting fact that the vertical lines issue don't seem to effect the menus whatsoever but rather everything around the menu regardless of video is shown, I'm trying to set mine whether the issue is the main board or the t-con board.
    Again what's baffling is that the menu is not effected whatsoever. However, any other video displayed regardless of inputs or when no inputs exist exhibits the vertical lines and seem to effect black areas only.
    The lines are green in color when the tv is in "Game Mode" and white in color when not in "Game Mode". Already tried service menu factory reset and switching the MRT "Lvds Format" which did not help.
    Any definitive feedback would be appreciated!
  • Diah
    • Feb 2013
    • 6363
    model name ?
    • E--Man
      • Oct 2017
      • 27
      Originally posted by Diah
      model name ?
      I am not home at the moment but believe it is un75hu 8000 series.
      Please let me know what you think and thanks
      • Diah
        • Feb 2013
        • 6363
        i would start cleaning the LVDS from both side first then .resetting them. if didn't help then MB. but its is easy issue could be repaired not for replace... clear high resolution photo will help
        • E--Man
          • Oct 2017
          • 27
          First, thanks for replying. Funny you said that because I already tried cleaning the LVDS connections yesterday between them but it didn't help. Also tried isolating which IC could be defective to trigger a change with low heat but it didn't help. I'll definately get you a high res photo. Do you want both boards or just MLB? No issue getting both if u think it'll help.
          • E--Man
            • Oct 2017
            • 27
            Here are the pics as requested. Anything you find will be very appreciated.
            If the resolution of these pics are not high enough just let me know and I will take even better ones.
            • Diah
              • Feb 2013
              • 6363
              from yours photo , the menu also effected with lines.. at least half screen could be seen, need to disconnect a time each half screen & also U ribbon on panel buffer boards a time to see if you will have 3/4 clear screen ..
              • E--Man
                • Oct 2017
                • 27
                Hi Diah,
                Could some the menu being effected have to do with the "Menu Transparency" setting? This setting is found in the System -> Accessibility menu.
                Please see the difference between Menu Transparency setting set to "Low" and "High" on the attached photos. The lines can still be seen on the "Low" setting but not as much as the "High"setting. Unfortunately there is no" Off" setting for the transparency!
                • Diah
                  • Feb 2013
                  • 6363
                  more or less you have them with menu.. so need diagnosing from the bottom .. go to panel buffer boards and disconnect one side U ribbon... for both side... no change then disconnect half panel each time from t-CON
                  • E--Man
                    • Oct 2017
                    • 27
                    I do not understand something. If I disconnect any connection in either T-Con or any of the U-Ribbons in any Buffer Control Boards then the entire screen goes black until restart. If I restart without ALL of the connections existing then all the entire screen is black, so how to diagnose? I cleaned all ribbon contacts and reseated - no difference.
                    Are you sure this is the correct path and it's not either T-Con board or Main board is the issue?
                    Thanks again.
                    • E--Man
                      • Oct 2017
                      • 27
                      This is what the picture looks like when you disconnect one side U-Ribbon from both bottom buffer control boards. What does this mean?
                      Disconnecting ANY cable from the T-Con results in black screen until restart.
                      • Diah
                        • Feb 2013
                        • 6363
                        Man i wrote one U ribbon at buffer boards a time then you will have 3/4 screen.and report back if the screen clean or not...... not as you did the bother disconnected..
                        please upload photo on whole the back of the Tv to see how and where the 12V T-CON come from..
                        al
                        • E--Man
                          • Oct 2017
                          • 27
                          al
                          Sorry if I misunderstood. When I disconnect one U-Ribbon the whole screen is black. Can you please be a bit more specific on exact steps?
                          Picture uploaded as per your request
                          • Diah
                            • Feb 2013
                            • 6363
                            now its clear that you have vertical and horizontal puffer boards, so when you disconnect one side left or right need disconnect the both on the side top and down one
                            one things more yours t-con take the 12V from the PSU... so please show the socket which it go to main boards.there should be print chart of the socket to know the pins name... so next step f it need to test T-CON and panel as stand alone
                            • E--Man
                              • Oct 2017
                              • 27
                              To confirm, you are saying disconnect BOTH U-Ribbon cables as shown in the attached picture as example? If yes, then when I do that I only get black screen with nothing. Also tried restarting and nothing.
                              If I am not understanding, can you please point what I should disconnect in the picture? Thanks again.
                              • Diah
                                • Feb 2013
                                • 6363
                                leave the U ribbon connected... what about if you disconnect half screen from T-con ribbon same way on top and down ?
                                if the screen remain black it mean we have opposite buffer boards will explain later
                                • E--Man
                                  • Oct 2017
                                  • 27
                                  Disconnecting ANY cable from the T-Con results in black screen. Maybe due to failsafe or board configured to stop displaying if it detects nothing plugged in?
                                  • Diah
                                    • Feb 2013
                                    • 6363
                                    i don't think so, since the panel operated with double buffers boards , much likely panel_VCC designed in way running over the whole rand of the screen. as usual we don't have any exact info on panel design.
                                    this why you need to try running the T-CON and Panel in stand alone mode... i asked on the print chart of PSU socket ..i will write here points of this try testing
                                    1- first of all disconnect the sockets between PSU and MB. to see if the LED BL come ON, in case yes ..check the Fuse on T-CON close the black socket which it connected to PSU if there 12V DC with reference to TV chassis. ( i don't think there will be 12V )
                                    2- measure on the PSU socket to know which pin Standby >3.3V and which Pin Power_on and if there one DRV_ON or T-CON ON the name yyou will know from the print chart on PSU
                                    after you notice all above and in this case of test you are ready to go further
                                    3- we keep the socket between PSU and MB disconnected, and disconnect the 2 LVDS from T-CON side
                                    4- here need we use 1KR to jumper the pins called DRV_On or Panel_ON or T-CON_ON what ever which responsible to turn on the 12V to T-CON with any PIN STBY on the socket or any other PINS which it had >3.3V
                                    if we are lucky the screen will turn on pattern color and at this point need to inspect if there are lines or not.. no lines mean T-CON and panel are fine.
                                    • E--Man
                                      • Oct 2017
                                      • 27
                                      Just started I'm on #4. Good news is that there are 2 fuses on the T-Con and both have 12.8 with reference to chassis and the backlight does come on with PSU to MB disconnected.
                                      See pics for #4:
                                      CNM803 = PSU to MB
                                      CNT804 = PSU to T-Con
                                      Can you please rephrase which pins to jumper?
                                      • E--Man
                                        • Oct 2017
                                        • 27
                                        Also posting picture of BL ON when PSU disconnected from MB. I notice that the sides of the screen show the BL but not in center of screen. Not sure if this is normal or not based on the technology
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • howardc64
                                          A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
