Sony DVD player stuck tray (DVP-SR310P)
  • bogosort
    • May 2022
    • 78
    I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
    Anyone knows why?
    Thank you.
    • 31183
    99% of the time it's the belt connecting the motor to the tray gears.
    you will find it at the front after you remove the tray completely
    otherwise maybe the motor needs oiling or replacing.
    but the belt is the main issue in most cd/dvd mechanisms
    • bogosort
      • May 2022
      • 78
      Thanks for the reply. Hopefully removing the tray is not too difficult.
      • lotas
        • Jan 2016
        • 4744
        • Russia
        There is no need to remove the tray, then you need to install it correctly, pull out the tray all the way and immediately turn off the power to the DVD (pull out the plug from the socket), now push the tray in with your hand for better access to the belt and remove it with tweezers, change it to a new one and apply power.
        • Xenon-Codex
          Sony CDP-295/407 tray opens only halfway
          by Xenon-Codex
          The mechanism works in other unit, and the working mechanism does the same in this broken unit. So the fault must be in the motherboard. Eject may open the tray with a second try, but it will not close or play any disc.
          11-02-2024, 12:30 PM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • mikey5791
          Sony CFS-5000S radio cassette player no FM reception
          by mikey5791
          Hi forum members,
          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
          I opened the casing inside and checked for any dry solder, burned component or loose wires...
          02-24-2023, 03:48 AM
          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
          09-06-2024, 05:30 PM
