samsung 50 inch plasma
    Re: samsung 50 inch plasma
    So just a slight glow from the bottom? I suspect you have a bad Y-buffer upper and Y-main. These are repairable and documented, but it's reasonably involved and you'll need a good soldering iron and preferably a hot air gun.
    • adamp91gvm
      • Jan 2014
      • 706
      • uk
      I have spare chips it's the second one down by the looks of it
        The second on top? You have to repair Y-main too, or the buffer will fail pretty quickly again.
        • adamp91gvm
          • Jan 2014
          • 706
          • uk
          Yer second down from the top on the top board yer I will do have to have a look how to remove the chip
          • adamp91gvm
            • Jan 2014
            • 706
            • uk
            What's the paste called that's used to re join the chip to the points I have seen a few videos on you tube and he heats it up and it solders the connections
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Err--Solder-paste!
              Doh--dont you just hate it when some smart-ass does that!
              TELEFIX
              • adamp91gvm
                • Jan 2014
                • 706
                • uk
                #27
                Ha ha did not know if it had a special name like everything else
                  I wouldn't use solder paste except for the bottom pad - it's too messy to rework a board with solder paste.
                  • adamp91gvm
                    • Jan 2014
                    • 706
                    • uk
                    #29
                    It looks very hard to solder each one of them points for that chip there very small
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      • uk
                      #30
                      https://www.youtube.com/watch?v=ZypX...e_gdata_player
                        It's one method. It's OK for low pin density like that. But it is a lot more difficult when the pins are so closely spaced. You get too many bridges, sometimes between pins almost impossible to take off.
                        It's not that hard, but practice on a scrapped board first.
                        The preferred method is known as drag soldering. Tack each corner with solder while holding the chip in, then drag the solder over each pin. Wick away any excess (the excess will be on top, so you can wick it easier - with paste, the excess gets between pins, or worse, underneath the chip, nearly impossible to remove.) If you get the speed right and use the right amount of flux, you won't even need to wick away the solder. It'll come away perfect.
                        See here:
                        http://www.youtube.com/watch?v=5uiroWBkdFY
                        He uses a bit of paste on corners and solders it, along with kapton tape to hold the chip in place - it's a personal preference, you can also just tack pins manually with solder if you don't have any paste.
                        If you do buy paste, be aware that the yellow stuff on ebay is essentially useless. You want the grey stuff. Flux can be in liquid form or paste form, either works.
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • porfyriadhs
                          Samsung Plasma PS51D6900DS Bootloop
                          by porfyriadhs
                          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                          Thanks a lot !!
                          10-19-2023, 11:31 AM
                        • ArMaaN376
                          Samsung PS51E550 Plasma TV
                          by ArMaaN376
                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                          Opened TV cover & observed foll
                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                          How to confirm Y -Buffer board...
                          06-19-2024, 04:05 AM
                        • CDNBrewer
                          Samsung Plasma PN43D450A2D No Power
                          by CDNBrewer
                          Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                          This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                          I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                          When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                          03-02-2025, 04:59 PM
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          Replaced emmc.
                          Terminal log
                          UART
                          AC_ON
                          E-B
                          FDE enabled
                          06-01-2025, 02:11 AM
