Q: is there a standard method to check a plasma screen?
+ More Options
Posts
  • loadedboyuk
    • Feb 2014
    • 26
    Is there any way to check if a plasma screen has gone bad?
    I have tried to repair a LG plasma which has no picture but I dont know how to check if the screen itself is still ok.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Q: is there a standard method to check a plasma screen?
    Well--Its difficult....
    Apart from obvious cracks, a set in otherwise good (working) condition with a PDP down to air,--will Buzz quite loudly if the PDP (Screen) is bad.
    Other faults include mal-discharge (Very common on LG)--red/green spots, sections of picture missing, can be a number of issues--But Generally--a Blank/lifeless screen--Isnt one of them!
    LG with no pic--what model? Common for IPM's to fail on 42/50PC1/3DA/ similar with the X3 chassis....
    TELEFIX
    • loadedboyuk
      • Feb 2014
      • 26
      Its a PS50C55. THE y-buffer board was showing earthed down, and the controller board was flashing every 5 seconds so I changed y-sus and buffer, but after 3 seconds with power on, it looked like the Y-buffer had another flash across it and the picture went off again. this is the 3rd LG i have had with no picture fault.
        There is no standard method as far as I'm aware. Never heard of PS50C55 LG. That sounds like part Samsung code. Maybe LG 50PC56?
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Zelek11
          Panasonic Plasma screen interference on left half of screen
          by Zelek11
          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
          10-14-2022, 04:54 PM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
