Trying to troubleshoot this tv. It's been working fine since last year when I had the no power/ replace the caps and everything's fine incident. However, the picture has started to go. It looks like a faded negative with odd color which is present using both component and coax inputs. No odd colored lines, no distinct solarization.
I've done both factory resets without resolution to the problem. But when I pull up the onscreen menu, the menu itself looks fine. Back of the input board does have some odd light tan color to it here and there but visually the boards look fine and there is no dust inside.
The picture doesn't look as bad as some of the the posts which required a tcon board replacement, but then again, I can't be sure what exactly happens when a tcon goes/is going.Thought?
