Samsung UE49KU6100KXXU no boot
  • JoeFlash
    • Dec 2021
    • 17
    • Hungary
    Hi! I have a TV, Samsung ue49ku6100kxxu, no boot, when connect the power cord, standby led and the backlight up and down repeated. When i disconnect the MB, the backlight is up.
    I take some measurement and all ok. I have already try tape method and same happen, if I disconnect both flex from mainboard to panel tv same happened. This is a software error?
    I have an IC programmer: CH341A
    MB model: BN41-02528
    MB code: BN41-02528A
    on the glued label: BN94-10826K
  • lotas
    • Jan 2016
    • 4753
    • Russia
    The jumper on the motherboard must first be placed between FB_TRDY_1 and FB_TRDY_3, and then the LVDS cables must be removed.
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      it will be of big help if you Please upload pictures
      • JoeFlash
        • Dec 2021
        • 17
        • Hungary
        I jumpered, and same happened.
        I upload a video, what exactly is going on.
        • lotas
          • Jan 2016
          • 4753
          • Russia
          It's strange, as if the video is empty, there is no picture. It is necessary not to disconnect two loops at once, but one at a time.
          You also need to check the signal lines on the hdmi and usb ports for short or low resistance relative to ground.
          • JoeFlash
            • Dec 2021
            • 17
            • Hungary
            I changed the MB, I take the measurements and good all, wired that what you say, and I have a picture on the right side of the screen and rebooted repetitively when connect the left side. Photo is the working.
            • JoeFlash
              • Dec 2021
              • 17
              • Hungary
              I have 3/4 screen when separrate 1st segmente.
              • lotas
                • Jan 2016
                • 4753
                • Russia
                Now try to disguise thClick image for larger version
ID:	3261973​ese contacts.Click image for larger version
                • JoeFlash
                  • Dec 2021
                  • 17
                  • Hungary
                  I tried does not fix it. Same happened.
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    You are masking the wrong contacts, they are on the left. Post the full photo of these contacts.
                    • JoeFlash
                      • Dec 2021
                      • 17
                      • Hungary
                      I tried these ways.
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        Take a high-quality photo of this area.
                        • JoeFlash
                          • Dec 2021
                          • 17
                          • Hungary
                          This is the best quality what I can take. If you want a can make more photos.
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            Measure the resistance on these legs relative to ground (these are TVS diodes, they often have problems with low or short resistance).
                            • JoeFlash
                              • Dec 2021
                              • 17
                              • Hungary
                              found a low resistance pin
                              • lotas
                                • Jan 2016
                                • 4753
                                • Russia
                                Try removing this assembly and checking again. If it doesn’t help, then the problem is in the panel and you will have to mask or cut this signal.
                                • JoeFlash
                                  • Dec 2021
                                  • 17
                                  • Hungary
                                  Removed. The smd marked "E5" seems to be good, I measure the same value on the panel. Test it and problem not solved.
                                  • lotas
                                    • Jan 2016
                                    • 4753
                                    • Russia
                                    Using a multimeter, check which pin this pin goes to on the connector and mask it.
                                    • JoeFlash
                                      • Dec 2021
                                      • 17
                                      • Hungary
                                      Masked and have a full screen, but there are horizontal stripes all over the screen.
                                      I still use the jumper between FB_TRDY_1 and FB_TRDY_3.
                                      • lotas
                                        • Jan 2016
                                        • 4753
                                        • Russia
                                        It is necessary to mask experimentally the adjacent contacts (usually 8-9 pin), the jumper will no longer be needed for diagnostics.
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                          09-07-2024, 05:50 AM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                          09-06-2024, 11:40 PM
