philips master/slave inverter
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    i picked up a philips 47pfl7432d/37 . the previous owenr said that the tv screen. would get dark on on one side of the screen. i opened the back up noticed the caps
    on "s" slave board were both only half on.i solidered them back on and powered up the set. the left hand side is a little darker than the right.
    will both boards need replaced (master &slave )?
    can i get a inverter board repair kit ?
    the slave board is. kubnk133lb. rev0.4 6632l-0393b
    the master is 6632l-0392b
  • truep
    • Aug 2010
    • 373
    Re: philips master/slave inverter
    Can you post a picture of the back of the set as well as the inverters? It does sound like a bad inverter. I would replace the caps on both inverters, and a"new" one if you decide to replace.
    Check the slave inverter board for shorted mosfets, and the driver chip for a hole or a burned out pin. These faults are common on inverters.
    • tocold4u2
      • Dec 2012
      • 284
      • usa
      after the set is on for 5-10 minutes the screen starts to get darker and darker
      and. you can hear the master board working harder.or so it seems.
      i was afraid one of the boards waa gona go out for good so i turnsd the powee off.
      this set is a 42pfl7432d/37. it has led lights in the back cover..
      anyone know where or what board they plug into ??
      so is the slave for the back light ? and the master for the picture?
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        not sure how these will show up...my camera is broke and i had to take pictures with my cell phone.
        • tocold4u2
          • Dec 2012
          • 284
          • usa
          just wondering if the slave should be replad or the master ??
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            Well i got a used set ..but there is still a dark shade on right side of the screen.
            I do believe that this slave inverter is failing .
            just wondering if a rebuild kit would solve this prolbem
              Can you show a picture of the fault?
              If you can get ahold of a neon bulb you can see if an inverter is working or not.
              • cheeky2
                Help with bypassing the OZ9928SN inverter ic from I470H1-20A MASTER LG 47LG5000
                by cheeky2
                Merry Christmas
                Does anyone know how to bypass the protection ic OZ9928SN on a LG 47LG5000 inverter using a I470H1-20A MASTER pcb?
                Pictures attached
                Thanks in advance...
                12-26-2024, 05:25 AM
              • x_orange90_x
                by x_orange90_x
                01-29-2025, 09:24 PM
              • crushkittykitty
                CMO I420B1-16A (27-D012836) backlight inverter master and slave
                by crushkittykitty
                origanlly the backlight would come on and go off in my great ability to repair I hooked up a test light per instructed master side top 6 would only partially light slave side lit test light fine, pulled tv down to bulbs, same bulbs inside only halve lit. seems master inverter at fault tested all transformers all seem fine, pulled top transformer from master double checking test points reinstalled cleaned up all connections noted on back of master center of board dark spot, checked around that area everything on top of board seems fine, resoldered the 0 resistors plugged everything back in turned...
                07-16-2016, 02:32 PM
              • JFarm
                Sharp Aquos LC-46E77UN inverter testing
                by JFarm
                I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
                The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
                03-21-2021, 11:10 AM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
