toshiba lcd 263030db no picture but has sound
  • homerclone
    • Jan 2014
    • 53
    • uk
    Hi
    Toshiba 26c3030db when turned on the tv has sound but no picture. when it warms up picture is displayed. before tv warms up it displays vertical redish vertical bars across the whole screen then picture returns fine. I have replaced the power board but problem remains.
    any help please?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: toshiba lcd 263030db no picture but has sound
    Check that you have replaced the cable to the panel correctly. Try removing, cleaning if it is a flat ribbon and replacing.
    • homerclone
      • Jan 2014
      • 53
      • uk
      I have just tried that but still no luck :-(
      • homerclone
        • Jan 2014
        • 53
        • uk
        Any more ideas
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
          I ordered a supposedly β€˜new' Tcon board this time, and
          06-09-2024, 10:28 AM
        • jord4231
          Toshiba 37AV500A Regza TV good power supply no sound no picture
          by jord4231
          Hi Everyone,
          I'm working on a Toshiba 37AV500A Regza TV.
          The issue:
          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
          I checked the PSU voltages and everything looked good.
          No bulging caps or signs of heat.
          24v aud = 24.41v
          12v = 11.98v
          5v = 5.062
          p_o/f = Goes high...
          03-29-2022, 09:21 PM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
