Toshiba Regza 42 XV 555 Backlight Problems
  • beanbean
    • Feb 2014
    • 5
    Hello all! If anyone knows, it's you guys!
    I'm an electrical engineer by trade (automotive) so not completely useless, but clueless when it comes to anything without wheels....
    My Toshiba Regza 42 XV 555 is being a pain. The screen went blank while watching with a pop/click that sounded like a relay shutting off. Or a cap popping.
    Anyways, been searching the net and playing with it for a few hours and turned up stumped...
    Picture can be seen using a flashlight on the screen.
    Power supply board is giving all the right voltages.
    Inverter board - getting 24V DC from the supply board on all pins, and all GND pins are grounded fine.
    However, there are 4 connections coming from the mainboard to the inverter (joining into the ribbon with 24V DC wires) that I'm not sure about - one GND, one reading ~1.9V, one ~3.3V, and one ~5V.
    Would the 1.9V likely be a backlight on command that should be reading >3V ?
    I haven't tested any of the AC parts of the inverter board as I have a cheapy multimeter I don't trust for it.
    There are 3 pink wires coming from the inverter, I would assume to the backlights - one from the bottom of the board, two from the top.
    Each half of the board has 2 coils. On the top half (with the 2 pink wires), there is a blue dipped/disc capacitor coming off the secondary side of the coils that doesn't really look bulgy. At least no more than a usual fat capacitor in my opinion, so I don't think it's that.
    What else could it be?
    The coils all going at once is unlikely, and so is all 3 backlight sections going at once.
    I can get a replacement inverter board cheap enough, but I'd rather be sure it's that (if indeed it is) before splashing cash on it....
    Thanks!
    Re: Toshiba Regza 42 XV 555 Backlight Problems
    Posting good clear pictures will be a good start.
    • beanbean
      • Feb 2014
      • 5
      Thanks for the fast reply!
      Picture album here:
      http://imgur.com/a/8iP25
      All voltages and pin names (that I could find) are on the pictures...
      Should probably add that all the capacitors on all the boards (apart from that blue one) look fine.
      • philliesfan30m
        • Aug 2013
        • 542
        i think that inverter board is known for the caps going bad without visible signs and also the 4 voltage regulators under that black piece of plastic that distributes the heat.
        • philliesfan30m
          • Aug 2013
          • 542
          probably should check the voltage on the fuse on the inverter board first. if you didn't already that would be a start.
          • philliesfan30m
            • Aug 2013
            • 542
            i'd also check out that ic chip to make sure it doesn't have any holes in the top of it. the 1 to the left of the capacitors on the inverter board.
              Those 4 MOSFETs under the black thermal transfer pad should be checked, also the caps and fuses as mention.
              • beanbean
                • Feb 2014
                • 5
                Cheers guys! Nothing's testing out of the ordinary so it's something I've missed or all 3 lamps went simultaneously.
                Got a new inverter on the way for quite cheap so I'll try that out.
                • beanbean
                  • Feb 2014
                  • 5
                  It was indeed the inverter board. New one in and all works again
                  Thanks very much!
                  • Jess
                    • Sep 2014
                    • 10
                    • uk
                    Hello Beanbean, I'm not sure you you still frequent this board but would you be able to state where you recieved the board for "quite cheap"? I have a similar issue and I can fgind the board for 50 GBP. Is that reasonable?
                    Thanks.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                      09-06-2024, 05:27 AM
                    • atltechnology
                      Toshiba Satellite L50 PSKXWA-01100M Schematic Diagram Board View
                      by atltechnology
                      I need the Toshiba Satellite L50 PSKXWA-01100M
                      This is my board no : daobltmb8fo rev f
                      model no : Toshiba L50D-C
                      Part no : PSKXWA-01100M
                      Give me Schematic Diagram Board View
                      01-14-2025, 04:21 AM
                    • lostone
                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                      by lostone
                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                      05-19-2024, 11:40 AM
