Sony KDL 40V3000 no audio
  • pbwizard1
    • Feb 2014
    Sony KDL 40V3000 lost audio using TVs speakers and checking audio at head set jack found no audio there either. Replaced Audio/Video board still no change in audio and television will longer recognizes the tuner board as a video input after the A/V board was replaced. Any suggestions on what to do next?
  • Ltank
    • Jun 2013
    • 776
    Re: Sony KDL 40V3000 no audio
    A lot of TVs have a power cable from the power Supply to the main board. Usually 12 to 18 vdc. Check power using chassis gnd as reference for meter gnd lead
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • Darren Hibbert
      MacBook A2179 Audio board+Power button boardview & schematic needed
      by Darren Hibbert
      Hi.
      Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
      There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
      Many thanks. ...
      08-21-2025, 02:38 PM
    • grimacelord
      MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
      by grimacelord
      I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
      12-11-2023, 11:13 AM
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
