Samsung PLASMA PS50C450B1W: Y-Buffer board Problem!!
  • Ahakim
    • Apr 2013
    • 64
    No light on screen. TV ON by TLC or by hand on front panel: power red led blinks once and TV goes back off. Relay can be heard switching on and off again repeatedly...
    When Y-main board or Y-drive Buffer completely disconnected: relay doesn't switch back off and green led on MAIN board remains lit.
    Most probably (my diagnostic says) there is a short on Y-Buffer...Am I right? Where Should I look for this short? There are 8 ICs of 33*4 pins each on the board! Are theese "microscopic" ICs replaceable? or should I look for a board for replacement? HHHelp!!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung PLASMA PS50C450B1W: Y-Buffer board Problem!!
    Unplug the buffer-board from the Y-Main, (can leave it connected to panel by the flex-connectors), plug all cables back into Y-Main and re-test.
    If it still trips, then the fault is unlikely the buffer-boards, but likely on either the Y-Main or the X-Main as the supplies loop from Y to X on these sets.....
    TELEFIX
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Also--If it trips, disconnect the X-Main thick cables and then re-test.
      If it still trips, then its likely the Y-Main is the culprit, and probably has a short on the Vs supply-line....
      TELEFIX
      • Ahakim
        • Apr 2013
        • 64
        Sorry...I don't really get what you said in the first reply. Can you be more explicit. Ok ...I'll try ... Thanks anyway.
        Note: There is only ONE long Y-Buffer board in this TV.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Ah--yes, should have thought, Have a couple of 50" buffers here, as you say--one long board--bit like the 42" version I have running here.....
          The Buffer is plugged into the Y-Main--yes? (Or is it the type--that has the Buffer--as part of the Y-Main,--all one board?)
          Unplug that buffer from the Y-Main, then re-test as above....
          A couple of pics would help clarify the chassis, the boards, the connections etc....
          TELEFIX
          • Taban
            • Jan 2014
            • 5
            • Spain
            hello, I had the same fail. At first time the tv was died. only can hear clikc the coil or psu. First I Replace the x-main LJ41-08457A, and the I have sound but no picture. After that I replace the y-main LJ41-08458A and the buffer board LJ-4108459A and the tv continues only with sound. when i begin to repair this tv a found a shortcircuit in the mosfet of the x-main. I bought these boards on flattvparts.com and they are used. I´m not sure that the boards are good. the last change its replace the psu, because the Va and Vs start good, but going down too fast when start power. if I disconnect the x-main board and the y-main board these voltages dont be ok.
            i bought the psu, used too, and i will try for the last chance.
            sorry for my english, I am from Spain.
            If somebody knows some solution I will be gratefull.
            thanks
            javier
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Sounds like you have bought some faulty boards and your original board/s have fault/s too...
              IS there ANY combination of boards from original and replacements that allow the set to 'run'--but have no picture-- as in--sound only, and the Vs etc stay supplied?
              How is your electronic knowledge...? Can you trace short circuits, test semiconductors, replace individual components etc...?
              If not, I would send those boards back to the supplier as (probably one or more) faulty, and get known working and TESTED boards from a different vendor.
              I have a full set of boards from a 50C450 set, BUT have NO IDEA if they are good or not, (therefore, I cannot sell them) they came from a broken screen set and I haven't a 50" set to test them in, Ive been waiting for a 50" to try them in to see.....
              Have you tested the Vsc voltage on the Y-Main? Ive had a situation with the 42C450--where this voltage didn't come up Fast enough (because I put a larger value cap in the stage) and the set wouldn't start on first attempt, Va and Vs were shut down by control board--Switch off, then straight away back on, would run normally all day till next day.
              Think maybe your Vsc isnt there, too low or something wrong with that inverter stage on the Y-Main--that is if there's no blown/broken parts obvious on the Y-Main.....
              TELEFIX
              • Taban
                • Jan 2014
                • 5
                • Spain
                I'm technician in electronics. I was working for 4 years in telecomunication electronic repair. Now I am working in industry electronics.
                Flatvparts.com say that they test all the boards, but I'm not sure. I'm not sure that the panel plasma its ok. But I will try replace all the boards. The last chance its replace the psu.
                The original fail was clicking the start relay. And the normal solution its replace the xboard. But I replace all the boards and I only get the sound. But the picture its dark. I will tell what happen when replace the psu.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Cooperr
                  Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                  by Cooperr
                  I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                  The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                  10-21-2025, 01:11 PM
                • ohren
                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                  by ohren
                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                  The models launched in 2018 and 2019 respectively....
                  09-08-2023, 05:24 PM
                • C152Heavy
                  Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                  by C152Heavy
                  Summary for TL-DR readers:
                  • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                  • Have obtained Samsung schematic & service documents - Can upload if helpful.
                  • Have read ALL applicable threads
                  • C1818 and CP820 replaced as low hanging fruit
                  • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
