Panasonic Tx-40cx400b top left half screen not displaying correct
  • armoured_smiler
    • Sep 2008
    • 13
    Trying to work out if this is TFT problem or TCon issue.
    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?
    Thanks for any info
    Paul
  • Diah
    • Feb 2013
    • 6399
    Thanks for any info
    Paul
    what do you mean with TFT ??
    this CX set had direct LED... please show the backside of all boards....
    • lotas
      • Jan 2016
      • 4670
      • Russia
      Thin Film Transistor (TFT) is a liquid crystal display manufacturing system based on an active matrix of thin film transistors.
      • Diah
        • Feb 2013
        • 6399
        this is wrong sorry.... TFT and LCD are 2 boats quite different ... MB video switching data are different... freq relay too .. recherche rate too-- so how can we compare both just by letters name ?????
        • Diah
          • Feb 2013
          • 6399
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            I had one of those and remember it having the panel side tabs only on one side, if yours is like that, it can't get better.
            • armoured_smiler
              • Sep 2008
              • 13
              Okay, my mistake been out of the loop didn't realise that TFT is no longer not the same as LCD, apart from that how can I prove if it is the LCD screen or Tcon board causing this issue?
              • Diah
                • Feb 2013
                • 6399
                at least show us all boards, to know if they are from vestel as well the panel
                • armoured_smiler
                  • Sep 2008
                  • 13
                  • armoured_smiler
                    • Sep 2008
                    • 13
                    So, is there anyway I can prove if it is the Tcon or panel that is the issue (without having to buy replacement parts which it or may not require)?
                    • Diah
                      • Feb 2013
                      • 6399
                      disconnect the LVDS from t-con and turn on... if the back light come on.... keep lvds disconnected and fed the t-con F1 with 12V from power boards rait
                      • sickboy
                        • Jun 2015
                        • 86
                        Does it display like this when using a different source than the PC? Also does this effect show when you select the menu, or the smart apps page?
                        • kca
                          by kca
                          Hello all ~
                          Yesterday, 06:38 AM
                        • howardc64
                          TCL 49S405 double image
                          by howardc64
                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                          06-23-2025, 03:20 PM
                        • Zelek11
                          Panasonic Plasma screen interference on left half of screen
                          by Zelek11
                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                          10-14-2022, 04:54 PM
                        • MoreMagnets
                          Sony KD49X8000H - Sound, backlight, no picture
                          by MoreMagnets
                          Hello all!
                          This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                          Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                          10-23-2022, 09:31 PM
                        • paqman
                          Vizio M60-C3 black screen
                          by paqman
                          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                          03-02-2024, 04:37 PM
