Samsung LE32R74BD. A(R)
  • Brass eagle
    Brass Eagle
    • Sep 2013
    • 8
    • Scotland
    I have purchased this Samsung LE32R74BD. A(R) tv for spares or repair I wonder if any members can advise me on the problem it has, when I power it on it flashes 3 times then a small glimmer of light like the screen is going to light up then one more red light flash then it shuts down ,I also have another tv the same make and modle and this one powers up but has a blue screen,I am wondering if I can make one out of he 2!
    ny help is appreciated
  • sordids999
    • May 2013
    • 2149
    • uk
    Re: Samsung LE32R74BD. A(R)
    Posting some pictures of the boards might help you
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      Service manual for your model can be downloaded here
      Give the webpage about 30 seconds to load then a small Get Manual will show up in the middle of the page under the document preview. I gave it a quick look through but didnt see any codes for the 3 blinks
      Liberating magic smoke one part at a time
        09-07-2024, 05:50 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
      • marcinq
        Samsung UE60KS7000 No Standby Light
        by marcinq
        I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
        I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
        05-26-2025, 11:36 AM
      • DXseekerMO
        Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
        by DXseekerMO
        Hello everyone!
        Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
        Symptoms:
        1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
        2) TV does not appear to turn on
        3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
        4) "Power on" terminal on Power Supply has 3.26v
        5) "A13V" terminals have 12.9v
        6) Stand-by test jumper on Power Supply has 12.9V
        7) Optical audio jack on Main Board illuminates
        8) With stand-by...
        06-09-2021, 12:19 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
