PHILIPS 63PF9631D/37 plasma with lines
  • football0062
    • Dec 2011
    • 98
    its an 06 when i got it the Xmain was shorted. replaced board with brand new one. when you first turn it on you can barely see some blue specles, but after a few minutes of warming up you will get horizontal lines. i replaced logic board also but nothing changed. Ive ordered y sustain will be here thursday but i dont know for sure thats the problem, i cant find a test pattern for the logic board. any thoughts?
    Re: PHILIPS 63PF9631D/37 plasma with lines
    Lines static or moving?
    • football0062
      • Dec 2011
      • 98
      moving and changing contentiously. even with signal board disconnected from main i still get those lines. when signal board is connected and i hit MENU alot more of the screen lights up but just a ton of spazzing lines
        Have you tried checking -Vsc voltage? Is that measuring OK?
        • football0062
          • Dec 2011
          • 98
          yes all voltages are there and adjustable. when i have it on the scope you can see the distortion from the lines after it warms up. only shows up on the Ysustain side, X is clear.
            I'd check for bad capacitors in that area, maybe floating 5V for buffer boards is bad. (F5V is relative to the -Vy voltage usually.)
            • football0062
              • Dec 2011
              • 98
              ok so just to be clear how exactly do i test for me F5v?
                For now, run the set cold, then heat up parts with a hairdryer, what makes it come back the quickest?
                • football0062
                  • Dec 2011
                  • 98
                  ok the hairdryer had the biggest effect on the upper chip circled in the picture. the screen started getting brighter and lines showing up more and more until bam a diode shorted and shut down. fuses are still good though. didnt turn it back on yet going to replace that diode first and check for more shorts
                  also before it went out was getting some really bright colors through the display
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Bet that IPM module is bad. I'd wait.for.the new ysus you ordered. don't want to risk damaging the Zsus again as its a possibility that in this TV 1 board damages the other
                    • football0062
                      • Dec 2011
                      • 98
                      The replacement Y sustain board did solve this problem. works great now.
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • ohren
                        by ohren
                        09-08-2023, 05:24 PM
                      • fredtred
                        Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
                        by fredtred
                        Hello!
                        I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
                        Problem
                        My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
                        (See Attachment 1)
                        Self Diagnosing
                        After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
                        10-29-2023, 01:09 PM
