I'm thinking of buying some single smd led diode for tv repair to have under hand there is so many, 2835 k-6000k 9v.6v, 3v white etc but don't know which to have if you advise me which Should I buy and which is most usual and bäst to have under hand. thank you
Buying some single smd led diode for tv repair, your advice needed
Go to ali express and pick up a couple multi packs. Generally you'll use a specific one more then others. These are more common for tvs.
THey aren't labeled great so you'd have to use an LED tester to see which is 3v/6v etc. the numbers
3030 for example means 3.0mm x 3.0mm
2828 would be 2.8mm by 2.8mm so having a caliper to measure your existing LEDs would be wise. I think I got one at harbor freight for like 4$ or something. I'm sure ali express would have a cheap one too
https://a.aliexpress.com/_msboZXU -
thank you so much for your reply. Should you not take into account the brightness of the light, and if they are rectangular or square and are not available that are labeled so that you do not have to search when you need them then you should choose the ones that have white light or?Go to ali express and pick up a couple multi packs. Generally you'll use a specific one more then others. These are more common for tvs.
Then why this thread has moved ? If you know
When you change a light, in my experience, first of all. If feasible always just get new led sets. Don't try and do single LEDs.
If you do single LEDs, yes brightness matters, an LED that has run 2-3 years is going to be less bright. So when you change an LED it's going to be brighter, what you can do, is test the whole line that led is on and see if it's brighter and/whiter. If it is (likely) then get a black sharpie and your going to put black dots in a circle around it. Like a ton of them, only around the bright led. If you do it properly, Google im sure has pictures, then it won't show as a bright spot on the screen.
Rectangular/square will show in the led number. 7030 will be rectangular and 3030 will be square.
Rectangular leds such on edgelit tvs, I have never tried to repair one, mainly because they are so close together that this would be very hard to do. Or at least I think I tried once, and ruined like 2-3 at once or something.
The question, why this thread has moved? I have no idea what your asking.Comment
i would say this will bring you at more headache, and at the end of the day you cant said its repair.
LED BL the type of LED you are thinking to buy are for Direct LED system.. which its impossible you can fit the lens on the top of LED 100% in center to avoid the generating light spot. this why at direct LED replace strips the professional method. also because if one LED dead mean the other will die soon.
Edge LED BL we can replace one or all with out fair of spot as there are no lens. for example i replace all 56 LED unit at edge 4370 double LED in just round 1 hoursComment
Diah and Eazybone are right. Just replace all leds strips. It’s usually much faster and less troublesome in the long run. There is a saying I use. Quit trying to save a penny just to piss a dollar away.
If your selling TVs and do this you will have pissed off customers or lots of warranty work or both.
good luckComment
by HondamanMy mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
She does not want to switch to Linux. And she does not want to use a laptop because...-
by jolivaresI sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
This is what i found until this moment:
1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
2) no short circuit in lines VCC_MAIN, VCC_BATT.
3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
4) the current draw from the power supply, without battery, is about 26mA from the charging... -
by bohabohaHi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
the one i choose is the D full Set
maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for... -
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by mariukonieSONY VAIO PCG-711911M VPCEH2H1E
Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks.... - Loading...
