Panasonic Th-50pz700u Vertical Line
  • B8ender2
    Slow Learnder
    • Feb 2014
    • 4
    • usa
    I've got a couple of vertical line that goes from the bottom to the middle of the screen. According to the Service Manual it could be coming from the D board ( control board) or the C5 ( data driver board) which control the lower center of the screen. My question is how can I determine which board it is or do I just replace. I think with my knowledge I can change out the D board but the C5 board i'm a little intimidated with the connectors going to the plasma screen. Any help and advice would be greatly appreciated.
    Re: Panasonic Th-50pz700u Vertical Line
    How thick is the line? Just a few pixels or an inch or more?
    • B8ender2
      Slow Learnder
      • Feb 2014
      • 4
      • usa
      It looks like about 4 lines. Each are as thick as a pixel. One a greenish color another is yellow, sometimes you see a purple tint and some a couple of very faint tan/white lines. It's on all inputs if that matters.
      • B8ender2
        Slow Learnder
        • Feb 2014
        • 4
        • usa
        Here is a picture of what it looks like.
          Unfortunately that line is an unrepairable panel fault
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • dajoker
            Panasonic th-p50s10d - blinky red, SC board go boom
            by dajoker
            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
            I chased my way through the PSU, and a board, with no results.
            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
            I only have the right half of the picture.
            Left half is completely blank.
            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
            all the other voltage rails...
            09-24-2024, 04:39 AM
