Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
  • signal.quest
    • Oct 2020
    • 50
    I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can partially fail? I am hoping it is not a panel issue, but maybe I damaged it by dismantling all of the layers. It was my first attempt at LED backlight repair. I also was delicate with the panel circuit board, but I am concerned about it. Please see the pictures for what display shows. Any help is appreciated. Thanks.
  • signal.quest
    • Oct 2020
    • 50
    Some additional information:
    Panel is Innolux v400HJ6-ME2 Rev C1
    Logic/Mainboard/A Board:
    TXN/A1YZUUS (TNP4G565)
    Power (P) Board:
    TXN/P1AEVUS (TNPA6029)
    Please help me verify Panel or Mainboard is OK. Thanks.
    • Diah
      • Feb 2013
      • 6503
      show us the back of the tv of all boards to see how they are connected to each other
      • signal.quest
        • Oct 2020
        • 50
        Thank you for the reply. I am in process of checking the panel board for obvious issues, therefore it has been partially disassembled. But I have connected it back to show the critical connections (not speakers or indicator light). Thanks. Please see the photos. Thanks.
        • Diah
          • Feb 2013
          • 6503
          under good magnifier check the contact pins of the LVDS cable at main boards side
          the one to panel with red and yellow mark need to check if there any cut at the cable side..
          the other U ribbon on panel buffer boards ( yellow ) check the contact pins too.
          • signal.quest
            • Oct 2020
            • 50
            I just checked all connection cable contact pins with a jeweler loop and I don't see any problem areas. The cable does has 2 bends/crimps in it that you can see from the photo. I suspect it was always like that but it is possible it got crimped when I had the TV dismantled and laying for weeks waiting for replacement LED shipment to arrive. Is there a way I can verify there are no breaks in the cable using a meter? Are those bends/crimps common or does it look like I made a mistake? Thanks.
            • signal.quest
              • Oct 2020
              • 50
              Here are the photos of the crimped/bent cable.
              • Diah
                • Feb 2013
                • 6503
                the crimped/bent cable.are normal,way to use for changing cable direction.
                you can try just disconnect the 2 on the right side of the U ribbon ( yellow mark ) and turn on the tv,, see if the screen will display half picture
                to check cable with DM. need to set the DM on peep ton option and check the pins of the socket from MB to panel one by one for connectivity
                • Diah
                  • Feb 2013
                  • 6503
                  this look for me Damage at LVDS
                  • signal.quest
                    • Oct 2020
                    • 50
                    Thanks. I will try that test. Do you think my logic (A) board is OK since it is recognized when laptop is connected to HDMI? Is there any other way to verify it is OK?
                    • Diah
                      • Feb 2013
                      • 6503
                      yes its fine..
                      • signal.quest
                        • Oct 2020
                        • 50
                        I assume then, the issue is something with the LCD panel? Are there common troubles with this type of panel? Or did I likely damage it from dismantling it to replace the LED backlights? I will try the troubleshooting steps you mentioned. What is the name of the integrated board to the LCD panel called? Is that the TCON or just LCD panel circuit board?
                        • Diah
                          • Feb 2013
                          • 6503
                          yours T-CON are interrogated with the Panel buffer boards. to test the panel.. you need
                          disconnect the LVDS cable between main boards and Panel , check on the PSU test point at Cold Area the 12V rail...
                          fed the Panel T-CON boards with 12V direct to fuse FP1 from the rail you found on PSU .. turn on the Tv and check the screen.
                          Notice. be sure the panel buffer boards had connect point to TV chassis
                          • signal.quest
                            • Oct 2020
                            • 50
                            If I disconnect the LVDS cable from the main board to the panel then I will have no power connection to the panel - is that correct?
                            I only have 1 cable that connects to the panel. I have previously used my meter and found 12V on the panel when the cable was connected. I know the panel board is getting power.
                            • Diah
                              • Feb 2013
                              • 6503
                              we know the panel power right now come via LVDS... this why i wrote disconnect the LVDS and power the panel fuse FP1 with 12V direct from the power boards.... this is test for panel.to have color pattern
                              • signal.quest
                                • Oct 2020
                                • 50
                                Ok, I understand now. I also can use a dedicated variable bench power supply to power the panel. How may amps does it draw?
                                • Diah
                                  • Feb 2013
                                  • 6503
                                  wrong... you don't need any external.... we need to use the TV power supply 12V,,, then when you power on the set the LED BL will come on so you can see the panel clearly if there are issue.
                                  • signal.quest
                                    • Oct 2020
                                    • 50
                                    The power supply from the TV only outputs 5V, 16V and 24V. The logic board provides 12V. Not sure how I can provide the 12V easily without another supply? Can I just power the backlight with the TV supply and the LCD with a dedicated bench supply?
                                    • Diah
                                      • Feb 2013
                                      • 6503
                                      take the 12V from LVDS socket on main boards and connect it to the fuse FP1
                                      • signal.quest
                                        • Oct 2020
                                        • 50
                                        I did the following tests:
                                        1. I disconnected both yellow highlighted connections in the picture you sent. This created a white screen on the disconnected side and colored lines in the center. Please see picture.
                                        2. I tried to disconnect just 1 of the yellow connection cables. This made a black screen on both sides, but the colored lines in the center.
                                        3. I checked the panel circuit for shorts on the capacitors but did not find any.
                                        4. I checked the panel board and found 12V, 3.3V, and 24V at different sections. I did not check all possible points. Please let me know specifically what is important to check?
                                        5. I used tape to block all lines on LVDS cable except the 12V line to provide power to the panel. I checked the board to ensure it had voltages, but the panel stayed black.
                                        Please tell me what to check for next. Thank you. I greatly appreciate it.
                                        • JSBJSB
                                          Panasonic OLED TX-65GZ950E no image
                                          by JSBJSB
                                          so I have this problem with this OLED that had a LED blinking issue at first.
                                          It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
                                          Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
                                          First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
                                          Then it started up and went to green light...
                                          05-14-2025, 02:39 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
