Red light but no power - alba tv please help
  • SmartestSmarty
    • Jan 2014
    • 50
    Re: Red light but no power - alba tv please help
    OK, I tried it again, this time I got.
    Red Wire: 12.71
    2nd: 12.71
    3rd: 12.71
    4th: 0.00
    5th: 0.00
    6th: 0.00
    7th: 0.03
    8th: 0.00
    • SmartestSmarty
      • Jan 2014
      • 50
      I tried again this time I got.
      Red Wire: 12.71
      2nd: 12.71:
      3rd: 12.71
      4th: 0.00
      5th: 0.00
      6th: 0.00
      7th: 0.03
      8th: 0.00
        It would appear the power supply is working then. Time to look at the main board, can you post a picture of it?
        • flocko
          • Nov 2012
          • 1121
          • uk
          on that socket or near by is there any thing screen printed to tell us what should be there it could also be on the other end were it go`s to main board has the power board got a part number on it?
          • flocko
            • Nov 2012
            • 1121
            • uk
            Sorry just looked at your photos again and your power board is mounted to the plastic body of the set so the mounting screws would not be grounded flocko
            • SmartestSmarty
              • Jan 2014
              • 50
              #26
              In the centre of the power board it reads, ACT 3611 / ERL28-T002 (Is this the board part number?)
              This is what I can see.
              • SmartestSmarty
                • Jan 2014
                • 50
                #27
                I appreciate all the help,
                Do you need any other pictures?
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  #28
                  been out cutting grass,well as Tom said 12 volt supply are there i thinks the 5V from the main must be there as well for the red standby led to light, so my best bet would be bad main board. and as such i would suggest a replacement board as i would think that testing and a repair on this would be beyond you at the moment.Look for part number on main board then search on Ebay. Flocko
                  • SmartestSmarty
                    • Jan 2014
                    • 50
                    #29
                    Thanks for the reply!
                    Are you sure? I am willing to give it a go; I have to learn someday.
                    I know how to change capacitors. So if you think It may be a bad capacitor, maybe you could tell me how I test them; and then I could change any bad capacitors if needed.
                    Kind regards.
                    • flocko
                      • Nov 2012
                      • 1121
                      • uk
                      #30
                      Bad capacitors are to blame in about 5% of Tv repairs and cannot be tested with a multimeter.And as most of the part fitted to your main board are SMD and would need highly skilled soldering for there replacement a replacement board is your best bet. Flocko
                      • SmartestSmarty
                        • Jan 2014
                        • 50
                        #31
                        Thanks. I am looking for a replacement board; however, I wouldn't mind attempting to fix this one myself. I can solder very well, and I'm sure there will be a youtube video out there explaining how to do SMDs. I don't mind if I need to purchase a different tester off of ebay or something. As you can see I like to learn and do things for myself.
                          See here for how to test voltage regulators
                          https://www.badcaps.net/forum/showthread.php?t=22231
                          try that on your board.
                          • SmartestSmarty
                            • Jan 2014
                            • 50
                            #33
                            Hello all,
                            I completely changed the main AV board, the screen now comes on, but I am getting only a white screen. Any idea why? or how to resolve this?
                            • flocko
                              • Nov 2012
                              • 1121
                              • uk
                              #34
                              Do all the numbers on he old main board match the new main? these have to be a complete match, also on the plug that goes to the T.con these board some times have more pins on the board then on the plug and needs to be fitted the same as the old one? so check these thing and reply Flocko
                              • SmartestSmarty
                                • Jan 2014
                                • 50
                                #35
                                Yes the board numbers were exactly the same. No worries I found the issue, I put one of the ribbon cables in upside down. Its all working now
                                  Good to hear, enjoy your TV.
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    • uk
                                    #37
                                    Good job hope you continue to learn on here and find more sets to repair Flocko
                                    • SmartestSmarty
                                      • Jan 2014
                                      • 50
                                      #38
                                      Thanks for all your help.
                                      I have another TV to repair; I'll start another thread for that one and post the link on here also.
                                      I look forward to repairing the next one.
                                      Thanks again
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • ipatch
                                        troubleshooting microsoft surface pro 4 no power no led charge light
                                        by ipatch
                                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                        10-05-2023, 11:59 AM
                                      • russpall
                                        LG 39ln540v - red light flashes twice, no power to LED driver?
                                        by russpall
                                        Hi there,
                                        I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                        The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                        08-27-2024, 01:07 PM
                                        03-31-2024, 02:12 PM
                                        Laptop computer that went completely dead no boot no power light no hard drive light
                                        See pictures for type of laptop computer
                                        I checked switching power supply brick 19.2 volts multi meter only
                                        No booting without switching power supply connected
                                        Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                        What the heck is going on here...
                                        04-04-2025, 04:58 AM
