Panasonic TXP50V10E Weird Display problems
  • Synergi
    • Dec 2013
    • 14
    • Austria
    Greetings badcaps community,
    I have a big problem with my Panasonic TXP50V10E plasma.
    Here some Images what are the problems:
    U can see horizontal and vertical problems.
    As suggested by tom66 in my previous post Previous Post
    I changed the A Board/Input Board. But the problem is still there.
    So back to the basics. (btw if u think I'm mad im not)
    So what could be the broken part?
    As side info, in the early stages it shuts down sometimes and blinks 7 Times which is the Code for SC Board Error.
    But in my mind, it can't just be the SC board because i have horizontal and vertical weird lines. But to mention i don't know that much about plasma screens and TV's in general.
    So i would say maybe there's just a cable broken or sth else? I don't know pls help me i want to revive my Screen.
    Sideinfo i have to sell a tested A Board OrderNumber: TNPH0795-1A if someone can use it pls feel free to contact me, florian.heider@synergi.at.
    TIA
    Synergi
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
    After all of...
    07-13-2024, 08:14 PM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
  • dajoker
    Panasonic th-p50s10d - blinky red, SC board go boom
    by dajoker
    My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
    I chased my way through the PSU, and a board, with no results.
    Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
    I only have the right half of the picture.
    Left half is completely blank.
    now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
    all the other voltage rails...
    09-24-2024, 04:39 AM
