Hi guys: anybody here owns an LCD VizioVW42L that i picked up and saved from going to the land fill,I've repaired it by replacing the four caps on the Inverter boards for the famous flickering now it's running great, but there is this clicking from the power sup when turn on or turning off that lasts a few seconds and then fades out is like a relay clicking any body t have this model notice this?
Lcd Vizio clicking!
Re: Lcd Vizio clicking!
I fixed about four of them but never notice that symptom.
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thanks budm: i can't say that's a symtom that afects the lcd it's been runnig for some hours now and it doesn't afect the performance so far,well i keep my finguers crossedI fixed about four of them but never notice that symptom.
http://s807.photobucket.com/user/bud...?sort=3&page=1Comment
Assuming...7 Photos -
by nbnbI have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
Any idea what is causing the clicking sound? Any easy way to... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... - Loading...
