Panasonic TX-32LX85F blink 3 times, P Board-power supply
+ More Options
Posts
    Re: Panasonic TX-32LX85F blink 3 times, P Board-power supply
    5077 seems to code for the version you have, though.
    • zeko
      • Jan 2014
      • 30
      • Albanien
      The power supply has the D854 not a 5V and this voltage comes from A-Board.
      D854 near PC801 secondary side.
      In addition to the IC802, is also A-Board with error???
      Or if IC802 works then is also 5V on D854?
        I'm lost. What do you mean?
        All the tests so far indicate IC802 is bad.
        • zeko
          • Jan 2014
          • 30
          • Albanien
          Yes the IC802 is bad. I only ask because of 5V on IC854.
          Signal from A-board comes later .. only starts IC802 and secondary is 24V, 17V and 9V be there. Is that so?
            IC802 should start as soon as relay power is applied. The PFC starts only when the A board sends the on signal.
            Probably the first thing the A board does is turn the main power rails on, checks they're OK, then turns PFC on.
            This also allows for the "recorder mode" (where the screen does not light, but the TV outputs video through SCART terminal to VCR) to be more efficient, as PFC is quite power inefficient, especially under low loads.
            • zeko
              • Jan 2014
              • 30
              • Albanien
              #26
              It means that firs comes 24V, 17V, 9V and then comes signal from A-Board for start PFC?
              If so, then the A-Board good.
                Yes, that's the idea. Recorder mode would only use about 10 watts, so no point in starting PFC. It is only legally required from 75 watts upwards, and would waste another 3 to 5 watts at that low load level.
                • zeko
                  • Jan 2014
                  • 30
                  • Albanien
                  #28
                  many thanks a lot
                  • zeko
                    • Jan 2014
                    • 30
                    • Albanien
                    #29
                    M-Power 2A Block Diagram, page 9.
                    • zeko
                      • Jan 2014
                      • 30
                      • Albanien
                      #30
                      it was bad IC802 MP2A5077 ..... many thanks it runs again
                      Another question,
                      can Arctic Cooling MX-2 thermal compound for PC is also used in LCD TV power supply, or must be one special thermal paste for an LCD TV?
                        You can use any type of non-electrically conductive thermal paste.
                        Arctic silver is quite expensive, nearly any old stuff will do the job.
                        • raulone
                          • Feb 2017
                          • italy
                          #32
                          Hi...i'm a new member..
                          i read all thread (with a very delay) because i've the same problem.
                          i ask to you: i can try replace the IC802 directly or i absolutely must do all checks?
                          Thanks!
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • cloo
                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                            by cloo
                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                            After doing a factory reset this problem was gone and the picture was back to...
                            01-06-2025, 06:02 AM
                            03-31-2024, 02:12 PM
                            After all of...
                            07-13-2024, 08:14 PM
                            07-01-2024, 06:34 AM
