Hi. Please help. I bought this TV completely dead. The seller said it was working fine and suddenly died. I had no reasons not to believe him. Looked quite rich, nice and clean, house. Not somebody selling second hand TV and needed to make extra money. Complete TV with accessories. I have replaced main board and TV come back to life but with picture as per photo - left side correct, middle and right like burnt OLED. Also on right side is visible ghosting. Would you say it is a panel faulty or main board I had from eBay? Shall I try different main board and tcon or take it straight to dump? Shame as TV is in pristine condition.
UE65HU8500T picture issue
hey MAN.... you bought boards from ebay. one look like yours.. but you dont know until now for which model series or size and which panel type it was working with it... in service menu we learn all this information and can be changed any time...... this is my last post. over here ,,save money as you wish.Comment
Remembers me an old case when.i repaired a quite old Sony LCD, there was dark, saturated, delayed bad side, i repaired it with a strange trick, interrupting the gate drivers vcc, turning on tv, tv.showed black,.then reconnecting vcc, this was maybe a reset or short killer, the trouble is panelComment
I am not sure what are you trying to say. Does the trouble is panel means the panel is faulty?Remembers me an old case when.i repaired a quite old Sony LCD, there was dark, saturated, delayed bad side, i repaired it with a strange trick, interrupting the gate drivers vcc, turning on tv, tv.showed black,.then reconnecting vcc, this was maybe a reset or short killer, the trouble is panel
Thank you for this advise. I will buy another one and try. If there is a hope there is a will
I believe this tv has side cof. As a last resort you can try removing cofs from the side that is affected.
if you have mobile device android with IR sender.. you can use this apk there are also hacked one .
if you are in service menu use this link for entry referencesComment
Thank youif you have mobile device android with IR sender.. you can use this apk there are also hacked one .
There is absolutely no configuration issue, who is telling you to buy boards or entering menu is totally out of the road, the image you posted show a correct image on the left but not correct on the right, this brings to only one answer, the tv hitted by an overvoltage or something gone wrong with the panel driving, depends on if the tcon is separated or not, now you have problems with the vgh/vgl signals so the row drivers can't turn on /off correctly the rows on the right, removing the vertical cof is an old technique, something better could be attempted, not by rookie user maybe.. you can also try the screen self test if you don't believe me, detach the MB, solder a wire between PSB 12v and tcon fuse input, insert current and.watch RGB test..Last edited by Davi.p; 05-19-2024, 07:03 AM.Comment
Thank you. That is very informative. So as I understand I should disconnect ribbon cable between main board and tcon. Connect 12V to tcpon fuse and it will start self test?There is absolutely no configuration issue, who is telling you to buy boards or entering menu is totally out of the road, the image you posted show a correct image on the left but not correct on the right, this brings to only one answer, the tv hitted by an overvoltage or something gone wrong with the panel driving, depends on if the tcon is separated or not, now you have problems with the vgh/vgl signals so the row drivers can't turn on /off correctly the rows on the right, removing the vertical cof is an old technique, something better could be attempted, not by rookie user maybe.. you can also try the screen self test if you don't believe me, detach the MB, solder a wire between PSB 12v and tcon fuse input, insert current and.watch RGB test..Comment
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
Assuming...7 Photos -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by mrautom8Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
While relay is on, all voltage rails are present and steady (scoped) on main board.
I love a good logic puzzle but getting lost without any schematics.
No shorts on ANY capacitor main board.
Thermal camera shows 3.3V inductor getting warm instantly but...-
Channel: Schematics and Boardviews
10-19-2025, 06:32 PM -
- Loading...
