My tv has started doing this. Any help would be greatly received. The white block bounces around the screen
LG 50PC1DA problem
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Re: LG 50PC1DA problem
Very informative thanks for quick reply. To save hassle there are loads on ebay but narrowing it down to the right ones im srruggling with. Typical come in pairs both upper n lower but which ones to buy ? These are tested but if there is a better option im missing be great to knowComment
You could also repair your board. You need to test each buffer as detailed in that link to see which is bad. eBay boards are a crap shoot. A great deal do not work at all.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thx tom. Is that par for course with ebay. ?Just trying to remember if I still got a multi meter from me mechanicing days . Im reading and posting from the pub so ill take a better look from lappy when I get home. As regard repairing how inticate is the soldering etc needed ? Again used to virtual blowtorch soldering than electronicsComment
If you've never soldered then you're best having someone else do it as it is fairly tricky work. I've done a similar board before, it's best with hot air. The repair cost is under £10 mostly, the FETs are usually cheap parts.
I've had good and bad luck with ebay boards. Generally there are only a few companies and individuals on there which test their boards well. The boards are also quite expensive due to the high failure rate.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
They are the three-leaded (if including the metal tab) devices at the top right of the board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hi tom ..this guy in link you sent is away. Is there anyobe else ? Alternativekt I have found some with right specs I.e 150 v 45.6a that are all but same number however pic looks like they have 3 legs and a taller top
Part no 671-5124 at rs components online websiteComment
i cross referenced the part numbers and came up with this
http://uk.rs-online.com/web/p/mosfet...stors/6875125/
Is the 46.5a necessary?Comment
Ok so i waited for the chinese new year to pass and ordered a load of FETs for the telly . They arrived and i had 6 new ones fitted to the buffer boards. On plugging back in bingo everything spot on .see pic 1
After two days i switched on and was watching telly for approx 2 hrs then the picture started flickering black and white , you could see a distorted pic through the black . if you press the menu button this was also messed up you could just make it out. I switched it off left it ten mins then switched back on and everythng ok. approx ten mins later it started again. sound is always spot on .
link to what tv does when flickering
https://dl.dropboxusercontent.com/u/...223_193232.mp4
any help appreciatedComment
video file is corrupt, but flickering dark mono/distorted colour picture suggests Z-SUS IPM failure.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Hi When you say video file is corrupt what do you mean ? is it two separate problems potentially .. if there was an a to z where should i be going next .
thanks for your quick replyComment
The video-file you linked to--doesnt work!!
--Replace the Z-SUS board.TELEFIX
Hold on -- could still be a Y-sustain fault. You'd want to check the -Vy, Vsc and Vzbias voltages to be sure... post a picture of the sustain boards if you need help with this.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by lazaro.089Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
CPU: Core i9-12900H
Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and... - Loading...
