Re: Samsung LE32M87BD - stuck in standby - blinking LED
still no change so its either wait for a cheep board or bart out the TV
in the oven now let you know how i get onLeave a comment:
it is soldered on, i've had success with a oven bake previoulsy on a 40 model, some flux under the shielded area with the shield removed and then cover the plastics and anything else you don't want to bake in foil, make 4 foil balls and rest the board on it then put it in the oven at say gas mark 4 for 10-15 minutes at most
not a great idea but only worth it if you have no other option or don't want to pay out for the board
these bordeaux models seem plagued with this, just to add further i've tried before with a heatgun and never worked permantly whereas the oven method has worked for me, plus a heatgun is giving uneven heat depending on how long you focus on the spot for flexing etc may occur whereas the oven is a steady heatLast edited by anotherdude; 01-23-2014, 04:54 AM.Leave a comment:
I don't know how the shield comes off, sorry. It's probably soldered down. Heat should be applied direct to the processor.Leave a comment:
so hot air gun directly to the chip ? - do you know how the shield comes off ?Leave a comment:
I would only use hot air on the processor directly - oven reflow is far too imprecise and unstable IMO.Leave a comment:
any simple way to reflow - i have heard of oven baking but there is alot of plasticLeave a comment:
Samsung main boards are never easy to fix. Most likely you would be looking at a problem with the soldering under the processor, like in the case of Xbox 360/PS3. You can try a reflow, but longevity is not guaranteed.Leave a comment:
cost of a new main board would take make this un-economical also there isnt any, is this some sort of cap or something i can replace ?Leave a comment:
Ok progress
I replaced the cap suggested by selldoor - no change
I then tried resetting the eprom - no change
I then tried the hair dryer on the top left shield as suggested by anotherdude - success the tv now comes on and it works fine
Now i know its the main board problem but how do i permanently fix it as when it cools down again it dosnt come back on ?Leave a comment:
try giving the main board a bit of heat near the shielded area, had similar before out of these models
might not be that but have had it before and won't do no harm to tryLeave a comment:
that was it in standby ( led constant )
when i tried turn on it went back to flashing 5 times then back light on for a sec and round and round
voltage back to 12.0 when trying to start - 12.7 when backligh stays onLeave a comment:
its only ok when the back light is on, when its trying to power up - ie led blinking the votages are low
in fact its got worse - they are now 0.07Leave a comment:
So not dropping out any more?
Sounds like main board fault - all voltages working OK.Leave a comment:
can you lable my photo then i will take you a close up picture of it
the back light has just got to the point where it stays on and the voltages have changed
the 12.05 v are now a steady 12.7Leave a comment:
It looks odd to me - the cover looks wrong and tipped so could be pushing the bottom?
Its also a 50v so could be the startup cap which might cause this?Leave a comment:
5 pins all at 24vLeave a comment:
Check the 24V for the inverter connectors, the readings are rather odd.Leave a comment:
when the back light fires up for a split second they then drop to nearly 0 but the back light goes off just before and they go back upLeave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by UkdiggerWhen the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
PSU number bn44-00610A L46SF_dpn
1 B13v 12.4
3 B13v 12.4
5 Vamp 12.4
7 Vamp 12.4
9 GND... -
by RusengaHi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
Connector CNM803:
TV ON
Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
TV OFF
Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...09-18-2021, 11:51 AM -
by rjuA sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the... - Loading...
