Samsung UN50KU6300F constant reboot, bad backlights?
  • vinceroger69
    • Mar 2012
    • 6714
    #61
    Nice to hear you have fixed the tv and another saved from landfill
      • 12167
      • U.S.
      #62
      It would be nice if they could all be fixed simply with a component or 2, but unless you work with them a LOT, it can be a real pain to figure out. Just had to retire a good old samsung ccfl from 2007, couldn't figure out the powerboard fault. Could have bought a replacement but had the back off so many times, there was nothing left of the plastic screw receivers to hold the back on and I'm always pretty careful not to over-tighten. Screwing metal into plastic it's so damn easy to strip it out, should stop at the first sign of resistance, beware using power screw drivers. A lot of manufactures have REALLY cheaped out lately, was recently looking at a Hisense 55-Inch Class A6 Series 4K UHD, cheap one board piece of shit, all plastic so the one board has to screw into plastic with a little piece of metal sitting on there, that's suppose to do the grounding I guess, is what they're thinking, shabbiest construction I have seen lately. Wonder if anyone started a thread topic on cheapest made junk they have seen, this hisense fits there. Small wonder I prefer the older tvs that actually use some metal in the construction.
      • x_orange90_x
        • May 2015
        • 718
        Wow that one does sound cheap! I cracked a Samsung curved trying to open it because the entire back is screw less. It snaps together all over and it wouldn't let go in one of the corners so the screen fractured.
        A tip that usually works for me with screws is to turn it backwards slowly until you feel it drop in the groove of the thread. It usually makes a slight click sound. Then you know you're in the thread.
        Putting this particular tv back together the other night was a pita because none of the corners wanted to live up with the screw holes. It was like it shrunk while it was off.
          • 12167
          • U.S.
          #64
          I hear that, wish I had a time machine, could go back and just refuse to buy any tv with these damn flimsy easy to crack as an egg shell and ALWAYS prone to shorting panels. They have better resolution and are bigger and lighter than the old crt but not nearly as reliable.
          • bohaboha
            • Nov 2012
            • 973
            • sweden
            #65
            Originally posted by x_orange90_x
            Here's the clip
            don't see anything on video
            • x_orange90_x
              • May 2015
              • 718
              They keep making the panels thinner too. I feel like my dent pullers are even too much sometimes for these panels. I get that they want TV's to be lighter, but today's 70" tvs only weigh 40lbs at most! At this rate, crazy-flying house flies will be cracking our screens in the near future!
                • 12167
                • U.S.
                #67
                I hear you, God forbid a gecko gets in the house and starts bumping into the tv. tv gone
                  09-07-2024, 05:50 AM
                • max789
                  Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                  by max789
                  Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                  I made the following tests:
                  1. Disconnected the main board from Power Board = backlight works.
                  2. Connected the main board and disconnected the T-Con = backlights does not work.
                  So I ordered a main board from Ebay also BN41-02156A but from...
                  01-18-2024, 06:56 AM
                • brkie
                  Samsung UE75TU6905 reboot loop
                  by brkie
                  I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                  I read on Samsung's website (reviews)...
                  09-04-2024, 01:45 AM
                  09-06-2024, 11:40 PM
